Its one of those IMHO its sometimes people so intent on having a 1 x set up that they overlook the fact its not the best fit and just keep engineering "solutions" to give it the range of 2 x and not quite managing it [or requiring new bits to achieve it like cages or freewheeels and the like]
The dropper post anaology would be to buy a dropper and then having to keep buying/engineering things to make the drop bigger and bigger. After doing this the drop is still not as good as just undoing your QR and dropping the post anyway but it will almost work as well as that.
Confused by the snake oil/magic beans references. Its a bigger gear. That's engineering and scientific fact. About as far from snake oil as you can get.
As others have mentioned it not just about easier climbing. You get a bigger range so could fit a bigger front, keep the climbing gear the same and have a faster top gear.
Yeah, like a product which will give you a bit more drop of your post.
And yet people will be saying "but I can still drop it an inch further with my qr". What's the point. And thus completely missing the point that they have to stop and get off to change it.
Perhaps it is a good analogy after all!
a solution without a problem
Dont get me wrong I think 1x works well for hilly areas but I would not want it in a mountainous area
YMMV
And of course we all know the next one will be 46t 😉
so we can have this discussion again later, woo hoo!
so there is nobody that wants a higher top gear or a lower bottom gear. You learn something new every day.a solution without a problem
I was out on my XC HT tail last night, my Whyte's awaiting an insurance evaluation :-(, which I run 3 x 9 with 22/32/42 up front and a 11-34 cassette. I found that I only used middle ring and never needed granny. Comparing to my Whyte which is 1 x 11 running a 32T chain ring and a 10 - 42 cassette the main difference is I spin out in top the lower range is good for the hills around Winchester.
Overall I'm happy with my 11 speed setup but when I go to mid-Wales in June I might change my mind.
I have no problem with 1x and can see how it works for some people it's just I lol at the attempts of many to justify it for everything. I also lol at the idea of spending a huge amount of cash to get less range. It's an option but is not a huge stride forward and is not the second coming.
As for bikes not being able to run a front mech, surely that's as a result of the fashion for 1x? There's plenty of bikes that can and I'm yet to read a review that states any bike is significantly better then another because it's designed to not have a fm.
I liked the response to my earlier post that mentioned the weight saving benefit of dropping the fm, shifter and cable on a 45lbs+ bike.
As with all bike stuff, as long as you can afford it then wanting it is enough of a justification. You don't need to make up loads of negligible arguments to supplement your choice.
I think you misunderstood!
The bike weighs about 23lbs, but when I use it for bikepacking and camping trips it can have 20+lbs of gear attached to it, and its for those trips that the phantom granny is left on as a rarely used bail out option, for the other 99.999% of the time I'm enjoying the benefit of a 1x with a NW ring.
I'm not going to bolt a shifter, mech and cable on, and remove the NW ring every time I go off on a trip where I might once in a blue moon need to use the granny, now THAT would be silly, for me a manual shift 2-3 times a year is worth it for the rest of the time.
does it come in anodized purple?
Oooh, how on trend with flats and a short cage mech as well 🙂
The other issue is you will need wider bars to fit your dropper lever, your front mech, your fork lockout and rear suspension lockout..............not to mention brakes. Where will it end ?
If I had the money I think I'd go with a DI2 double setup and just use 1 shifter in syncro shift mode, seems a ****ing brilliant idea.
A quick fag packet calc suggests than a 10-44 cassette actually comes pretty close to matching the overall range that my old 2x9 managed (11-32 + 36/22, i.e. You can either have the same bottom or top ratio depending on weather you prefer a 30t or a 32t chairing, and give away about two tooths worth of extra gear at the other end... So 10-46 might just do it.
Like I say same overall range, obviously not all the same possible ratio combinations, but as people often like to point out due to "duplication of ratios" there's probably only about 12 to 14 useful gears in amongst the supposed 20 a 2x10 drive offers, I don't reckon 11 sequential gears is such an awful compromise set against that.
for my own part In have learned to love a lower range shimano 1x10; MTFU for hills and accept "spinning out" on the odd boring flat bit...
Different strokes for different folks innit...
It's not like multiple ring setups will vanish, flogging extra parts to the luddites is still profitable... 😉
But even the adherents have to admit it is a compromise and that is for gearing as yet not available
I would rather compromise on a 2x set up if I needed a 44 rear.
Its personal choice though but the while point of gears is to increase the range of gears. Self limiting them to almost enough [ with some faffing and in 1 x 10 additional components and much expense] is not my opinion of an advancement.
YMMV
its not a new thing.. ARI have had them out for a while.. I replaced the 42T on my xx1 cassette when it cracked..
http://www.aribike.it/pignone%20sram%20XX1%20html/ari%20cog%20for%20sram%20xx1%20cassette%20eng.htm
[quote=Junkyard]even the adherents have to admit it is a compromise and that is for gearing as yet not available
Everything is a compromise, you just have to pick your one.
[quote=Junkyard]Its personal choice though but the while point of gears is to increase the range of gears.
The point of gears is to give you the option of more than one gear.
[quote=Junkyard]Self limiting them to almost enough [ with some faffing and in 1 x 10 additional components and much expense] is not my opinion of an advancement.
It is just a different compromise. Some people don't much like the extra noise and complexity and weight of a front shifter and multiple chainrings. They also feel that they can ride most of what they want with a more limited set of gears.
[i]
"I applaud this test, but I still feel that variable gears are only for people over 45. Isn't it better to triumph by the strength of your muscles than by the artifice of a derailleur? We are getting soft. Come on fellows. Let's say that the test was a fine demonstration - for our grandparents! As for me, give me a fixed gear!"[/i]
You're forgetting that those that think anyone who doesn't run 1x is an idiot and front mechs are the work of the devil will already have 1.5m bars with plenty of room. I would suggest front and rear lockouts would be scoffed at in a similar fashion to a proper range of gears though.
[i]Probably would have had the same threads about forks and discs if there had been a forum back then.[/i]
you have no idea.... 😐
wish i could "spin out" 32×11 ... I'm lucky if i can hold 120rpm
for more than a few seconds 😉
I manage to fit 2 brake levers, 2 gear levers, 2 lockout levers, 2 bar ends and 2 grips on 60cm bars (no dropper, grumble, grumble, new fangled technology).
Can I just check, are bar ends still allowed if you're running 1x?
Can I just check, are bar ends still allowed [s]if you're running 1x?[/s]
No.
Not even gold anodised ones?
[i]Especially [/i]gold anodised ones!
And of course we all know the next one will be 46tso we can have this discussion again later, woo hoo!
[url= http://int.oneupcomponents.com/collections/all-products/products/45t-sprocket-18t ]OK, so I was wrong, the next one is a 45T[/url], can't be long now though 😉
