40mm PVC pipe and c...
[Closed] 40mm PVC pipe and coupling to install crown race?
[#9461635]
Don't fancy splashing out on a proper tool when a couple of bits of PVC will do the trick.
I guess 40mm is the nearest/cleanest sizing I'm gonna get to 1.5"? Coupling necessary to seat over the race.
Ta
Posted : 27/07/2017 12:56 pm
Cut a slot in the race instead?
Posted : 27/07/2017 12:58 pm
Buy a Hope crown race instead 🙂
http://www.ebay.co.uk/itm/232321145782
For a fiver, it's cheaper than the tool!
Posted : 27/07/2017 12:59 pm
Result. Couldn't remember which one I had sitting around - turns out it's a Hope. Sorted. Ta.
Posted : 27/07/2017 1:07 pm
I've installed a crown race with some piping but cut a slot in the bottom of the pipe, overlapped the pipe, used a ziptie to hold it to the right diameter then roughly filed the end so it was flush. Tapped it in with a rubber mallet. Super bodgy but it worked, used a similar method to knock in a hub spacer as well.
Posted : 27/07/2017 5:02 pm
 OCB
I use MDPE inserts for this job. I find them pretty robust, but still 'soft' enough not to mash things. Cheap, come in a range of sizes and are easily available from your local plumbers merchant / farm suppliers.
Posted : 27/07/2017 6:03 pm
[quote=legend ]Cut a slot in the race instead?
That.
Unless it's [i]actually[/i] a Crown Race of course - and not a baseplate.
Posted : 27/07/2017 6:39 pm
