40/42t expander spr...
[Closed] 40/42t expander sprockets
[#6423631]
Are you changeing yours with every casette or bringing them over to a new casette? As it's the bottom sprockets that skip and shift badly when a casette is dead don't see why I shouldn't be able to move mine over? In theory a 42t sprocket should last almost 4 times an 11t due to having more chain/tooth interface. Anyone tried carrying one over yet?
Posted : 19/08/2014 9:34 am
You should be fine for at least 3 cassettes worth of changes I'd have thought.
But it all depends on how long you've spent grinding away in that gear.
IMO
Posted : 19/08/2014 10:24 am
I try to use it as little as possible as it's more expensive than the casette, chain and chainring put together! I should be ok then, cheers
Posted : 19/08/2014 10:36 am
By the time it's worn out we'll all be buying dedicated shimano 11spd cassettes.
Posted : 19/08/2014 2:22 pm
