4 bolt rotors for R...
[Closed] 4 bolt rotors for Rohloff
[#5139694]
Does anyone know why there is such a wide variation in price for Rohloff 4 bolt rotors?
Mono Mini rotor £26 - http://www.sjscycles.co.uk/hope-mono-mini-2-4-saw-tooth-4-bolt-rohloff-rotor-160-mm-prod17831/
Shimano/Formula £66 - http://www.sjscycles.co.uk/rohloff-brake-disc-for-rohloff-speedhub-500-14-160mm-for-shimano-hayes-formula-avid-8281-prod17834/
How different can they be? My rotor is about 6 years old and quite worn, I would replace as I'm getting some new Shimano brakes, but is it worth the extra £40 to get the 'Shimano compatible' one?
Posted : 09/05/2013 10:10 am
They're all made by Hope - my guess is that it's because the Mono Mini one is an off-the-shelf rotor from Hope, the Shimano one is a custom-cut one.
If the outside diameter is the same (i.e. 160mm) and the braking surface isn't narrower (which it won't be) then it doesn't matter - apart from maybe aesthetically.
Posted : 09/05/2013 10:14 am
As long as the outer diameter is correct you won't die and even if it is you can sometimes get away with a roter that's 5mm out (some 160mm calipers will accept 165mm roters and those that can't can be spaced out with washers).
Posted : 09/05/2013 10:15 am
Yes - though I've occasionally had vice versa - some rotors (especially wavy ones) aren't the outer diameter they say they are.
I fix it with a Dremel or angle grinder 😉
Posted : 09/05/2013 10:29 am
I don't care enough about aesthetics to spend the extra £40 so cheaper one for me. Thanks!
Posted : 09/05/2013 10:48 am
IME Hope rotors are ever slightly thicker than standard shimano rotors, which means they can be a bit of a faff to setup with Shimano callipers, that applies to all designs, not just Rohloff.
FWIW, I have a Hope rotor and XT calliper on my Rohloff and have no problems.
Posted : 09/05/2013 10:53 am
