3x9 Octalink chainr...
[Closed] 3x9 Octalink chainrings
 PJay
[#7761539]
I'm still riding a perfectly viable 3x9 XT Ocatlink drivetrain (cutting edge in 2003 I think). I replaced the aluminium middle and granny rings with steel Deores years ago and they're still going strong but I'm starting to think about changing the outer ring.
I vaguely remember some sort of issue running Hollowtec II chainrings on Octalink chain sets. Does anyone know if I can fit [url= http://www.chainreactioncycles.com/shimano-xt-fcm770-9-speed-triple-chainrings/rp-prod38183 ]these XT triple outer rings[/url] to my venerable Octalink chainset? If they're not compatible, what options are there?
Posted : 11/04/2016 8:09 pm
I think it was the middle position where you had problems. There were "tabs" that sopped non shimano chainrings fitting which may stop newer ones also. I used to run SS on octalink. I just filed the spider, it was only about 0.5mm near each bolt.
Posted : 11/04/2016 8:59 pm
I can't answer your question, but I've got some new or barely used big rings you can have way cheaper than CRC. Email in profile if interested.
Posted : 11/04/2016 9:05 pm
It's the middle ring tabs that cause the fuss when fitting new Deore rings to my Deore Octalink chainset, soon fixed it with a Dremel though.
Don't recall ever having the same problem with the outer ring, but then again it got swapped for a bash ring some time ago...
Posted : 11/04/2016 9:41 pm
