3M 2228 rubber tape...
[Closed] 3M 2228 rubber tape - equivalent?
[#11480898]
Starting a frame build today and for once I’m after something tidier than the old inner tube chainstay protector. Seen the 2228 tape recommended but I cannot see it under £20 a roll; is there an equivalent from a B&Q or somewhere similar for a fiver??
Ta.
Posted : 15/11/2020 12:30 pm
Marsh Guard Slapper Tape is a better version of a sticky tape for less money, but I use self almagamting tape from Screwfix (£5) works fine as long as you want to wrap a tube.
Posted : 15/11/2020 12:40 pm
I have self-amalgamating tape on one bike's chainstays and 2228 mastic on the other, both do an OK job but the self-amalgamating tape is thinner and gets torn up over the course of a year or so.
It looks like that Marsh tape is more expensive when you factor in the length you get?
I think the 2228 is good value when I can do a chainstay, undercarriage and some other random bits like mudguard mounting areas with a roll. And it's extremely satisfying to apply IMO.
Posted : 15/11/2020 12:47 pm
Yeah I don’t want anything thin; pointless to me. I want to get the look, wear rate and reduced noise that you’d get from the type that comes as standard on some frames. I don’t want to wrap it.
If the 2228 stuff is the only one that’ll do the above then that’s what I’ll have to plum for I spose.
Posted : 15/11/2020 1:00 pm
How about putting inner tube under the self amalgamating tape? Tidier finish with the increase protection of the inner tube.
Posted : 15/11/2020 1:05 pm
Can by a 1.6m length here for just over a fiver?
Only 1” wide but ok for a chainstay?
eBay
A
Posted : 15/11/2020 1:42 pm
Thanks Andy. Looks the better cleaner option for me. Now I just need to find a seller who’ll get it to me quicker.
Posted : 15/11/2020 9:49 pm
andysmiff1
eBay
A
That is just a 300mm length, its 1.6mm thick mastic tape.....
Posted : 15/11/2020 10:00 pm
Isn't an inch way too narrow?
Or are you going to coil it?
20+ vat
https://www.vikingtapes.co.uk/products/3m-2228-scotch-rubber-mastic-tape-50mm-x-3m
Posted : 15/11/2020 10:04 pm
On reflection I’d rather have it too wide then too thin - and I could sod off the protector on the other bike if it was thicker. I’ll hit Amazon then for a full roll if no one does an equivalent.
Posted : 15/11/2020 10:06 pm
Last time I fitted some of the 2228 tape to a bike a friend asked if the manufacturer was now doing a moulded chainstay protector for the bike.
Go with the 2" and take the time to do some CAD work first. (Cardboard aided design).
Posted : 15/11/2020 10:11 pm
andysmiff1
eBay
A
That is just a 300mm length, its 1.6mm thick mastic tape…..
Oh yeah.....that’ll teach me for posting too quick!
A
Posted : 15/11/2020 10:12 pm
Onzadog has got it. And I get it from Amazon it’ll come with enough for many goes at CAD 🤗
Posted : 15/11/2020 10:26 pm
O also sound the edges needed a little trimming as the adhesive was a few mm shy if the edge. That 2" stuff is more like 45mm.
Posted : 15/11/2020 11:36 pm
Noted, Onzadog.
Blimey, Viking tapes want a stoopid amount for delivery so another option needed cos I’m not paying that. Anyone know of any major retailers that stock it; B&Q etc?
Posted : 15/11/2020 11:41 pm
There is nothing as good and I've not found a high street retailer carrying it as it's a specialist product.
Any way if you want a job doing properly etc. Farnells have all sizes and delivery is £3.95 1 inch here - also do 2" as well
Posted : 16/11/2020 9:07 am
Long shot..... You near Manc?
Posted : 16/11/2020 9:13 am
What frame is it for?I've used Nukeproof chainstay protectors on my last two bike, just need a bit of trimming and extra glue.
Posted : 16/11/2020 9:21 am
VHS slapper tape looks great, but never in stock in the UK.
Posted : 16/11/2020 9:23 am
Nothing as good as 2228, sticks to frames, unlike the cheaper alternatives.
I've been using Specialized S-Wrap HD bar tape on my G1, stays clean, quietens chain slap as is durable.
Posted : 16/11/2020 10:51 am
The Generalist. Thanks but no, I’m in Milton Keynes.
Bagstard. It’s for the new Scandal 29’er and my Rose Uncle Jimbo.
Steelforreal. Thanks, that looks a better price.
Is this a gap in the market. I know a lot of brands are putting better options on frames as standard but there must be loads of people out there with frames that could benefit this product vs a neoprene option?
Posted : 16/11/2020 1:26 pm
For a knock-off version of 2228 tape?
Possibly, but it would have to be very good.
I did think it was expensive when I bought my first roll, but once I saw how good it was and what it could do on the bike, I thought it was very good value.
Posted : 16/11/2020 1:48 pm
Thanks steel4real, looks like the 50mm job will be about £25 from Farnells, but if I get a bike or three out of it...
Posted : 17/11/2020 12:03 am
