3D printer owners. ...
3D printer owners. Do me a big favour?
[#12869487]
I need a 22.2 to 31.8mm handlebar shim. These only seem to be available from US bike shops and I reckon this is an ideal use case for 3D printing.
Would any of you owners be kind enough to make me two of the below? Obviously beer tokens or a donation to your favoured charity would be a fair exchange. Thanks.
Posted : 26/06/2023 1:52 pm
To hold your handlebars? (presumably BMX/Cruiser bars?)
Nah, I've done a couple of seat post shims in PLA and they're still working fine, but the worst case for their failure is my seat post slides down and I look like a tit. I'm not sure I want to help you with your DIY dentistry project...
Good luck...
Posted : 26/06/2023 2:02 pm
 cp
3d printed in metal maybe, but I think there's too much risk that plastic will alter properties too much under compression and with varying temp.
I wouldn't.
Posted : 26/06/2023 2:07 pm
Agree with @cookeaa, not sure plastic is the material of choice here
Cheap BMX stem a la Charlie's Karate Monkey might be a safer solution?
Bet you someone with a lathe would knock you it up for very little; bit of 1-1/4" bar stock, bored out and parted off, you could just (neatly) hacksaw it down the middle and file to finish...
Posted : 26/06/2023 2:11 pm
Yeah, PLA really isn't a good option for the amount of torque and load it'll need to hold. Even on something like 100% infill, i just wouldn't put plastic between bars and stem.
(this is an ideal usecase for a friend with a lathe or mill, and a piece of metal. subtractive manufacture, the math still checks out).
Posted : 26/06/2023 2:15 pm
question: (EDIT: asked a stupid question, ignore me)
Posted : 26/06/2023 2:19 pm
 P20
Posted : 26/06/2023 2:20 pm
@infovore Isn't that plastic for a Garmin mount or similar?
Posted : 26/06/2023 2:21 pm
Fair enough chaps, appreciate the thoughts. I assumed that a bit of distortion into the faceplate cut out and working in compression wouldn't present too much risk of failure. I'll find another solution. 👍
infovore - spotted those, (SJS is my goto place for unusual bits). I need a smaller ID. You can get 22.2 to 24.5, but stacking multiple together definitely feels like a big risk of slippage.
@cookeaa ah yes, the answer to your question is "probably not, that's made of rubber". apologies!
Posted : 26/06/2023 2:22 pm
I'd happily knock one up on my mini lathe for you but the speed potentiometer is broken so I can't do it until the new one turns up.
Don't you need 2 pieces rather than the 1 in your diagram?
Posted : 26/06/2023 2:43 pm
That's kind of you Murray, If I don't' get sorted I'll maybe get in touch with you in a few weeks.
Don’t you need 2 pieces rather than the 1 in your diagram?
Yes, but identical so I didn't draw it twice, or as cookeaa noted a tube of the right ID/OD and I can cut it in half with a hacksaw.
Posted : 26/06/2023 3:23 pm
Murray reacted
Can you not just use a 24.5 stem? I have an Easton 100mm stem which I use with Soma bars.
Posted : 26/06/2023 4:09 pm
Would one of these work?
https://www.ebay.co.uk/itm/223114791066?chn=ps
Posted : 26/06/2023 4:45 pm
benp1
https://www.ebay.co.uk/itm/223114791066?chn=ps/blockquote >
That's made of rubber, so definitely not
Posted : 26/06/2023 4:47 pm
I could, in fact there's one on there at the moment with a 22.2 to 24.5 shim, but it's not the right length/angle/colour combo and I can't find one that's not 31.8.
Posted : 26/06/2023 4:55 pm
What length/angle/colour combo are you looking for? This could be a "stealth add". ;o)
What bars are these for anyway? I'm intrigued.
Posted : 26/06/2023 5:25 pm
What bars are these for anyway? I’m intrigued.
Something like a Surly Sunrise or Moto-X  I imagine? My Surlys came with a 22.2-31.8 adapter.
Posted : 26/06/2023 8:07 pm
ajantom has it, very much like the Surly Sunrise but actual motorbike handlebars (cut down a bit) as they're loads cheaper! I want to get it properly finished off before pictures.
Posted : 26/06/2023 11:44 pm
What length stem are you after, there's loads of BMX stems about in all sorts of lengths.
(Also intrigued)
Posted : 27/06/2023 1:29 am
