[Closed] 36/22?
[#2664721]
I'm corruntly running a 36/26 double up front but, as i'm woefully out of shape, I was gonna fit a 22t granny.
Will this work with the 36t or will the jump be too big?
Posted : 15/04/2011 2:19 pm
It's a big jump when downshifting under load on a climb.
It will work but it's just not that useable and you have to use the front mech more thoughtfully/in a different manner.
EDIT: I have it on two bikes and am happy enough to keep it until all my 9sp stuff is worn out
Posted : 15/04/2011 2:22 pm
Cheers. I'll give it a go but maybe i should stick with the 26t and get fit!!!
Posted : 15/04/2011 2:40 pm
 wors
Works fine on my bike.
Posted : 15/04/2011 2:44 pm
I think the double and bash SLX is 36/22. It shifts fine, but is a big jump down. I just dump it down to the granny on a big or steep climb and twiddle away.
I have that on my bikes. Waht you need to do is use 1-5 in granny and all in the 36 - so at the bottom of any climb where you might need granny shift down on the front and up on the back - then use the whole range of rear gears in the granny ring.
Sort of like a low ratio box in a landrover
Its perfectly usuable. You can never have too low a gear
Posted : 15/04/2011 2:47 pm
cool, deff gonna give it a go then.
Depending on what 36t ring you have, shifting up from a 22t granny may not be as smooth as with a 36t SLX ring, for example. Your 36t may have ramps designed to pick up from say a 26t or 24t inner, whereas SLX 36t is designed to work with a 22t inner ring. How much difference it makes in the real world I don't know, but if you like the 36/22 combo you might go for an SLX 36t or equivalent come replacement time.
Posted : 15/04/2011 2:57 pm
 D0NK
36/22 with an 11-32 cassette.
It is a big jump but the TA ring I have aint bad. 36x32 isn't as low as I'd like so I end up dropping into granny ring a lot more often than I used to.
Bigger cassette or a 34T ring might be better.
Posted : 15/04/2011 3:10 pm
Have had an SLX 36/22 double and bash with 11/34 at the back for a couple of years. Absolutely no problem at all
Posted : 15/04/2011 3:15 pm
woefully unfit was well but manage just fine on a FS with 36/24
Posted : 15/04/2011 3:17 pm
I've got 2 bikes running a doubles 36/22 and 34/22 - the 34 has slightly better shifting from the 22 but it has XT whereas the 36 has SLX. Not ever been an issue though.
I don't want to change the 36t but could do with some lower gears. ATM i'm usinig a Deore crankset that was originally a 26/36/48, but i dropped the big ring and fitted a bash. I fancy upgrading to an SLX in future anyway so may aswell get used to it now.
Posted : 15/04/2011 3:24 pm
I use 22/36 with no issues whatsoever.
Posted : 15/04/2011 3:28 pm
You won't need to change the 36T ring. On another bike I had an LX chainset, went to double and bash and just lobbed a 36T Deore middle on it, no discernible difference between that and the SLX 36T ring.
Nice one, cheers for the replies.
Posted : 15/04/2011 3:32 pm
Works perfectly, and Shimano sell it as a standard option on some cranks.
Posted : 15/04/2011 6:05 pm
cheapie deore rings are made of steel and last longer than the flashy alloy XT ones, slightly heavier but very little in the grand scheme of things
Posted : 15/04/2011 7:29 pm
Those who switched from triples, how has it affected your DH speed ditching your big ring?
Posted : 15/04/2011 7:42 pm
bigyinn - Member
Only on tarmac or fireroads does it make a difference to me... You lose only the top 3 ratios, compared to a 44T, remember. By the time i'm going that fast on any interesting surface, I've got no thought in my head about speeding up, it's all about slowing down 😉 There's times I have to spin faster than I used to though, before i could slow mash a higher gear. But that's no problem.
Posted : 15/04/2011 7:49 pm
I can spin a 36 /11 top gear to 30 mph - 25 easily. I find offroad I rarely want to pedal faster than that. IIRC its only the top 2 gears you loose
Posted : 15/04/2011 7:55 pm
Currently running 46t and cant decide whether to keep 46t, to drop to a 44t, or ditch the big ring altogether.
Posted : 15/04/2011 8:38 pm
