36 ring for road bi...
[Closed] 36 ring for road bike -is it possible??
[#4376312]
Has anyone fitted a 36 tooth rear cassette to a road bike? My bike has sram red on at the moment and i am not getting enough rides in to build up any fitness - only used it 3 times this year 🙁 got a few big rides coming up and am seriously considering fitting as big a ring as possible. I know sram do the wifli kit with the 32 tooth ring, but is this as easy a gear that can be fitted?
Posted : 18/09/2012 9:41 pm
Ive got 11-36 on road/cx bike (in touring mode), although mines shimano, 105 10 speed shifters and XT 9 speed Derailleur. Any bigger than a 32 and i think your looking a derailleur change.
Posted : 18/09/2012 9:47 pm
Am expecting to change mech, chain and cassette
Posted : 18/09/2012 10:20 pm
 Haze
I'm only (a little bit familiar) with Shimano and have read of MTB cassettes being fitted, depends on rear derailleur capacity I believe.
Not sure if SRAM works on similar principles...
Posted : 18/09/2012 10:24 pm
You probably need a longer cage rear derailleur. Also look at changing your chainrings. You can at least get down to 33 on a compact 110BCD chainset, possibly smaller.
Sean
Posted : 18/09/2012 10:52 pm
Are there not new longer cage either Apex or Rival rear mech's that a 34 or 36 can be fitted ?
Posted : 18/09/2012 10:54 pm
If it were a shimano 10spd road setup with shimano STI levers:
A 10spd MTB cassette would fit onto a 10spd road wheel no problem ( i.e. 10spd XT stuff )
You would need a normal or shadow style 9 speed mtb rear mech to reach across a 32t mtb cassette.
You would need a shadow style 9 speed mtb rear mech to reach a 36t mtb cassette.
A 10spd rear mech has a different cable pull ratio and would not work with the 10spd STI
I have a 32t XT cassette with an XTR rear mech and 10spd Dura Ace shifters. Works very well.
I think SRAM has a different cable pull ratio, so the shimano rear mechs are out of the questions. I think the Apex range can accommodate 36t cassettes. I think Apex rear mechs have a longer cage anyhow so that may not be an issue.
Posted : 18/09/2012 10:59 pm
yes you can fit a longer cage mtb mech all mech/shifters can be inter mixed. all work on the same pull.
Posted : 18/09/2012 11:02 pm
Big road rides needing a 36 tooth rear cassette 😯
Where ?
What's your chainset? If it's a compact 50/34 then do you really think you need a 36 rear? If you're unfit I can't see how that can help.
Posted : 18/09/2012 11:08 pm
