no reason why this wouldn't work?
Anyone done it tubeless?
I toyed with the idea but gave up due to the max pressure recommendations on the Stan's rims. I am running 700 x 32 Specialized Borough tyres on my Tri-cross with a normal stan's conversion kit in them at 50 psi.
I might ask JRA. I doubt they'l recommend it but if they don't come up with a cogent reason not too then I might try it. Actually I could try it on my 29er archs first 🙂
I bet it would ride way better than tubes 😀
Interesting. notubes says that you can ONLY use the hutchinson tubeless tyres, but they'll work on std rims. I don't understand how they say std tyres will "stretch adn blow off" when they do not do so with a tube in them.
Will continue my research.
