Anyone else had this?
doing a cheap as chips chainset for a mate, swopped over the 32 tooth to a 34, because I had one handy and front mech needed raising to clear the bigger middle ring when running the big ring. Only now the bottom of the cage is too high when I move to the granny ring and rubs, even with chain under tension.
Is the only solution to go and buy a 32? or run a double.
Posted : 15/02/2011 11:56 pm
Or get a bigger smaller ring, if I understand your problem right?
Posted : 16/02/2011 12:00 am
Thanks, put in a couple of wanted posts, smaller middle or larger inner.
Posted : 16/02/2011 12:11 am
