30.9 seattube- 30.8...
[Closed] 30.9 seattube- 30.8 or 31.0 shim?
[#455884]
Frame runs a 30.9 seatpost.
Been offered a 26.8 Thomson at a good price, but can't find the correct shim.
Would a 10.8 or 31.0 have more success, or should I just get a post that fits!?
Posted : 07/04/2009 8:49 pm
 IA
If I was gonna bodge it, I'd be tempted to go for the slightly larger shim and then if need be take some wet n dry paper to the outside of it to reduce the diameter a fraction.
Posted : 07/04/2009 8:55 pm
 Mike
I'm after a black inline 26.8mm If that's what you have and could swap you a silver 30.9mm if that's any good?!
Posted : 07/04/2009 8:58 pm
Any photos Mike? Silver ain't my thing, but may be easier to swap a silver for black..
Posted : 07/04/2009 9:03 pm
i have a black 30.8 thompson that fits in a giant perfectly thats ment to be 30.9 going spare?
Posted : 07/04/2009 9:05 pm
 Mike
I'll just go take some and mail them to you asap...
Posted : 07/04/2009 9:09 pm
I bought a 27.2 thomson post the other week and needed a shim to get it to fit my specialized frame which is 30.9
I decided I would be best off getting the 31.0, I did and bingo, it works perfectly.
Theres a slit line down the length of the shim anyway, so you can compress it slightly to fit.
Posted : 07/04/2009 9:22 pm
 GW
thomsons are available in 30.9 I'd wait til one turns up for sale.
shims are hellish if you raise/lower your post often, plus I've also seen frames crack from the stress they cause.
Posted : 07/04/2009 9:55 pm
Any luck Mike?
Posted : 08/04/2009 8:48 pm
