30.9-31.6 seatpost ...
[Closed] 30.9-31.6 seatpost conundrum
[#1921517]
Building up an MMMbop tomorrow with some luck. All parts have arrived except the 31.6mm outer post for my Joplin (currently is a 30.9)
Could i shim it using a beer can so i can ride in the mean time? will it be thick enough/too thick?
Posted : 22/08/2010 11:09 pm
Just use a beer can.
Posted : 23/08/2010 8:22 am
If Carlsberg made shims 😉
Posted : 23/08/2010 1:47 pm
personally, I'd wait for the right part or use another seat post until it arrives. Would be a shame to damage a new bike for something like that.
Posted : 23/08/2010 1:53 pm
I used a Coke can. I think you'll need about 2 full shims to fit till you get the proper post.
Posted : 23/08/2010 2:15 pm
 Tim
Yep 🙂
Cut it too long, but snip it at 5 mm intervals, flare the ends over so it hooks over the seat tube, whack the seatclamp over the top...it'll work fine and it wont sod off down into the tube and get stuck 🙂
Posted : 23/08/2010 2:29 pm
your lbs probably has a shim.
Posted : 23/08/2010 2:55 pm
a shim that is less than 1mm thick - me thinks not!!
Posted : 23/08/2010 4:11 pm
My thoughts too. Coke can shim until correct post arrives.
Posted : 23/08/2010 4:34 pm
racing_ralph - Member
Yep USE make a 30.9 to 31.6mm shim
Posted : 23/08/2010 4:53 pm
where from?
Posted : 23/08/2010 5:29 pm
 goog
USE ?
Posted : 23/08/2010 5:32 pm
http://www.use1.com/product/2/000062/seat-post-shims/
Posted : 23/08/2010 7:23 pm
Got mine from Winstanleys
http://www.winstanleysbikes.co.uk/product/31366/USE_Seatpost_SS_309mm_Shims
showing as in stock
Posted : 23/08/2010 7:55 pm
just ordered one from winstanleys cheers
Posted : 23/08/2010 8:13 pm
A special shim from the private stock of Baron Alfred Krupp, who had to sell it at a great sacrifice?
Posted : 23/08/2010 8:22 pm
How do i find out how thick the shim walls will be? 3 wraps of can and its still not a tight fit 🙁
Posted : 24/08/2010 10:18 pm
