30.6 in a 30.4?????
[Closed] 30.6 in a 30.4?????
 devs
[#608144]
Anyone tried a 30.6 seatpost in a 30.4 frame such as a Nomad for example? How tight are the tolerances?
Posted : 05/06/2009 3:08 pm
Depends on the tolerances of both, as you've said. I've seen it done with a 27.4 in a 27.2 before, guess it's a case of suck it and see.
Posted : 05/06/2009 7:50 pm
if its a bit tight then sanding it down might be enough to get it to fit. beware of getting it stuck tho
Posted : 05/06/2009 7:56 pm
In engineering terms a heavy press fit for a 30 mm hole requires a 30.05 mm shaft.
With a post 0.2mm bigger than the hole it just ain't gonna fit.
http://www.mitcalc.com/doc/tolerances/help/en/tolerancestxt.htm
Posted : 06/06/2009 12:05 am
If only bike manufacterers worked to those tolerances, eh?:)
Posted : 06/06/2009 12:15 am
which ones?
Posted : 06/06/2009 12:16 am
the tolerances where the difference between 30 and 30.05 is considered relevant. I measured up various seatposts all supposedly the same size and there was at least 0.15mm difference - same with 20 mm axles
Posted : 06/06/2009 12:37 am
Most of them, especially the lower to mid price ones, I regularly come across frames that look like they've been bored out with a rusty drill bit, and seatposts that rattle around like a d**k in a shirtsleeve.
Posted : 06/06/2009 8:19 am
if the tolerances are against you you get an interference fit. That plus a bit of corrosion, and in a few weeks time you have a one piece frame and seatpost combination...
I'd maybe try it on a cheap frame, but on something good I'd get the right size post.
Posted : 06/06/2009 8:35 am
Here Here to sanding it down. Almost guaranteed to corrode in situ once you get it in, but if you never adjust it, what's the problem. Remember to buy a silver post, cause it'll look awfully scruffy if you sand down black
Posted : 06/06/2009 9:06 am
A Nomad's a 30.9 surely?
Posted : 06/06/2009 9:12 am
[url= http://www.santacruzbicycles.com/nomad/index.php?geometry=1 ]Exactly ![/url]
Where on earth did he find a 30.6 ???
Posted : 06/06/2009 9:39 am
you won't spend £30 to finish a £1700 frame?
Posted : 06/06/2009 9:45 am
 devs
Blimey! I could have sworn my Nomad was 30.4. I was just looking at those on -one sale carbon seat posts and wondering if a 30.6 would fit. Al, the frame has been finished a long time but the post looks worn. I would replace it if I thought it was worth it but if I ain't getting a bargain I ain't getting it! 😀
Posted : 09/06/2009 12:43 am
 devs
Can't see any 30.6 posts now. I'm going mad or I dreamt it or something. Beer required I think.
Posted : 09/06/2009 12:48 am
