I like my gears. My knees like my gears. I also like my single speeds, my knees not so much. After a brief experiment I figured I could get by with 3 gears, one for your typical singletrack fun, one for going up those really steep hills and one for coming down fast or commuting in a hurry. So here's the question, has anyone tried a sturmey or other type of wide range 3 speed hub for such activity. If so how did you get on? Can you still walk?
Always wondered why they didn't just improve my Grifter gears, I suppose they did, with Rohloff. Up, down and along would do me though.
Got a hub on the shelf waiting for exactly this experiment to commence, think it is a 5 speed though, slippery slope only wanting 3 when 5, 8 or 11 is so easy to obtain 🙂
the problem is surely once you add the selector parts the added weight of each gear is probably negligible. I quite fancy dinglespeed though on my el mariachi as commuting on 34-20 is really spinny, but I like riding with a high cadence off road normaly so its fine for that.
I acquired A couple of SA hubs ages ago intending to try just such a thing out... Never got any further than that.
Quite liked the idea of thesturmey archer s2 Kickshift hub. Gears but no shifters... Apparently not all that durable though.
You want one of [url= http://www.profileracing.com/estore/product.php?productId=13 ]THESE[/url]
Would be very sleek with a miniature road mech.
Thank me later.
That Polish made in a shed planetary 3 speed system looks like it could be interesting. It would be perfect for my off road commuter.
Hammered my Nexus 3sp for a coupla' years - fun, but the range is waaay small. Then water got in and it died.
Might as well have an Alfine8 if you want a hub gear system.
hubstripping.com ?
What's the width of the Profile hub? 110mm?
Why not just run a single cog at the back and a triple at the front? That'll do you about right.
They never seem to have a wide enough range. I'd want a 22/34, 34/20 and 46/11 equivalents...
Because you'd need a rear derailleur to take up the slack when you're not on the big ring?
I know it's not 3 speed or hub gears but my knees have given out and I've gone 6 speed on my Hope SS hub with a Zee short cage mech. I was running 33-17 with a 9 speed chain. Couldn't get a 10 speed chain on the Surly front ring to match the clutch mech. So now running 32 Hope front ring with the 15, 17, 19, 21, 23, 25 sprockets off a 105 cassette.
All works as it should and I haven't dropped the chain once. The three big ones are too spinny for anything other than what you would use a granny on a full geared bike. You can't stand up a gurn up a hill, you just spin the back wheel with no traction. So it's taken a bit of getting used to.
Sturmey do a 3 speed with 135mm spacing, 6 bolt disc mount and thumbshifter - less than £100 for everything.
Lighter than an Alfine and felt much more direct and less mushy (pawls rather than roller clutches). Proper direct drive in middle 1:1 ratio (Alfine isn't direct drive). Ratio mix was good for Lakes etc in UK, but broke me trying it in Austria (reverted to backup 7 speed derail. on a Hope ss cassette hub).
Downside is no sealing whatsoever, weak axle and chainline not very good with regular mtb cranks.
Nearly there, but not quite.....
I like singlespeeding but another gear for the road sections would be brilliant.
Please get on with it.
Ta 🙂
The Sturmey ratios were pretty much spot on for expanding a singlespeed range - the low gear was just low enough to take over where you would be stalled out ss (or dying from leg cramps on a long day out). The high gear was just high enough to make progress on the road whilst not spinning like a ****.
Slightly bigger jumps would be OK, but anything replicating the absolute extremes of a triple setup might not be very rideable in reality.
That profile hub is for bmx hence the 110mm oln
