[Closed] 2x9?
[#5892825]
I want to change my current 3x9 set up to 1x10, but at the moment can't afford to do it all in 1 hit (clutch mech, cassette, shifter, narrow-wide ring, new cables) so for now am just going to do away with the big ring and run a 2x9 + a double chain device. Not quite sure on the length of chainring bolts I need to get to do ditch the big ring and just bolt the middle back on though. It's an slx crank by the way!
Any help much appreciated cheers
Posted : 26/01/2014 2:18 pm
if you're fitting a bash, your standard bolts are good.
If you aren't fitting a bash, you want 'single ring bolts' - I've used teh cheap ebay Onza ones successfully - the RF steel ones are stronger if you're a masher, and still only a couple of quid from CRC. Think I got a bag of five for my slx crank...
Posted : 26/01/2014 2:21 pm
Nope, no bash - they'll be spot on cheers mate!
Posted : 26/01/2014 9:40 pm
