2x1 setup? anyone t...
[Closed] 2x1 setup? anyone tried it?
[#5182128]
I've been thinking about a double chainring, single sprocket setup on my cross bike....
I know, I know, it's a dumb idea but....
I thought a rear mechanism as a tensioner would work...anyone tried it and got any pics??
Posted : 22/05/2013 11:48 pm
I "tried" it when my rear mech got stuck in one gear, it was pants. 🙂
Posted : 22/05/2013 11:56 pm
Why not have 2x2...
If the difference between cogs at each end matches then the chain length should be the same.
Posted : 23/05/2013 12:28 am
Hammerscmit? (or however you spell the thing)
Posted : 23/05/2013 12:33 am
Is this the name of a bike built from a Messerschmitt crashed in Hammersmith?!
Posted : 23/05/2013 1:27 am
http://www.sram.com/truvativ/products/truvativ-hammerschmidt-am-crankset
Posted : 23/05/2013 1:59 am
Google "Dinglespeed", as described by takisawa2.
Posted : 23/05/2013 7:19 am
There's been a few of these threads recently,
Does your frame have singlespeed compatable dropouts?
If so, dingle speed is a good option. If ran it a couple of time. works a treat if all the teeth add up to the same on both combos.
If its a vertical dropout frame, just stick with the sping loaded tensioner, ones with more wrap like pauls, rohloff etc will handle the jump between cogs better.
Posted : 23/05/2013 7:24 am
I did, I was running sliding dropouts and didn't want any tensioner so stuck a chainring in the middle to take up the slack. It was a PITA but good to get a higher gear as some of my rides were 50% road.
2 gears for off road...I'd stick with 1, the challenge makes it fun 🙂
Posted : 23/05/2013 7:30 am
 Keva
I tend to ride dinglespeed on my commute, been thinking about it myself. Very rarely change gears on the back but change from 32-44 on the front for subways, junctions and crossings etc...
Posted : 23/05/2013 7:43 am
How does one change gear on the dinglespeed?
Do you have to get off the bike and move the wheel in and out?
Posted : 23/05/2013 8:31 am
Yep,
two cogs front, two cogs rear, swap the chain over.
Posted : 23/05/2013 8:53 am
