2nd hand Meta 5.5, ...
[Closed] 2nd hand Meta 5.5, advice please!
[#3179347]
Is this a good idea? I didn't pay a lot if attention to the failure issues at the time, as I wasn't in the market for one, but I know there were problems. What model year should I avoid? Are these ones on EBay likely to be ok?
140610572890 or
260859774087
TIA 🙂
Posted : 24/09/2011 10:40 pm
 iolo
2007 were ok.
I've got a small for sale. £130
Posted : 24/09/2011 10:42 pm
2009 was the bad year. Large and XL frames the worst.
2010 were sorted - I have an '08 and it's awesome.
Lots of info on http://www.commencalownersclub.com/
One good suggestion is to make sure there's plenty of seatpost inserted in the frame as some failed around the top tube/seat tube junction.
Posted : 24/09/2011 10:49 pm
Thanks all. I need a medium, thanks anyway.
Posted : 25/09/2011 12:01 am
140610572890 is a 2010 Medium.
260859774087 is a 2009 medium.
Whilst you could get a perfectly fine 2009 model, it's probably not worth the risk. Medium's are not guaranteed to be crack free either. I have a 2009 medium & it has cracks on the shock mount welds and a hairline on the seat tube / top tube weld (rides fine at the moment).
Posted : 25/09/2011 2:04 am
 eemy
I bought one - 2006 or 2007 I think - off here incidentally and it cracked after 3 months use, where the top tube meets the head tube. It was a size Large.
Posted : 25/09/2011 9:00 am
Make sure you ride one before buying as I thought it sounded ideal but didn't get on with it on a test ride. It was great down hill but I just couldn't climb on it. A friend has one and he's fine on it though so your mileage may vary.
Posted : 25/09/2011 9:30 am
I had a 2009 medium that cracked and got replaced with a 2010 frame. The welding and general build quality on the new frame is far higher. I would avoid any 2008 or 2009 frames. The 2010 model is clear to see as the downtube is down tube is curved slightly at each end a bit like a stumpy and has a squared profile. The pre 2010 frames have a straight downtube with a round profile. Also the 2010 model doesn't look to have been welded by a chimp.
Check for any play on the rear swingarm as the main bearings can wear and are expensive to replace. As long as you get a good one you'll not be disappointed.
Posted : 25/09/2011 12:13 pm
they ride like a gate
Posted : 25/09/2011 12:15 pm
Er, no they don't.
Though tbh I've never ridden a gate so what do I know.
Posted : 25/09/2011 2:23 pm
i didn't like the ride at all mine; sold it on after 18 months - most of the time it was hung up not being used.
Posted : 25/09/2011 3:26 pm
 br
[i]I bought one - 2006 or 2007 I think - off here incidentally and it cracked after 3 months use, where the top tube meets the head tube. It was a size Large. [/i]
My buddys' did this too, at some time during a hard day in The Peaks - in fact the last two descents were the Roman Road and the drop into Lady Bower...
Posted : 25/09/2011 5:38 pm
