29er - Wide or Narr...
[Closed] 29er - Wide or Narrow Bars?
[#1263582]
Building up the Scandal at the moment and was just trying to work out what bars to go for. Just trying to work out the basic physics. The wheel is bigger so therefore slower to respond therefore smaller bars will improve this?????? Is this correct?????
Posted : 26/01/2010 9:16 pm
Noooo!
Go W-I-D-E
with a titchy stem 😉
Posted : 26/01/2010 9:21 pm
Wide apparently but not as wide as possible or you'll get stuck.
Posted : 26/01/2010 9:22 pm
Whatever your arms and shoulders feel comfortable with. Don't try to work out how it rides before you've ridden it.
Posted : 26/01/2010 9:46 pm
 Andy
Tootall +1 stick anything on and try it out first
Posted : 26/01/2010 9:56 pm
Same size as you'd use on any other bike.
Bar size has **** all to do with wheel diameter.
 ton
780mm
Posted : 26/01/2010 9:58 pm
ton - you haven't got a P by your name
ssstu has
Posted : 26/01/2010 10:06 pm
Yes Ton where's your P
Commoner. 😛
Posted : 26/01/2010 10:10 pm
 ton
i am skint, saving for a £2400 frame................ 😉
Posted : 26/01/2010 10:20 pm
Can you order it in my size and I'll give you a deposit on it now. 😉
Posted : 26/01/2010 10:22 pm
 ton
cough cough cough
Posted : 26/01/2010 10:35 pm
Go wide in alloy and if too wide, lop a bit off until it feels right. When it's finally right, if you want a carbon bar, try to buy one at that width.
Posted : 26/01/2010 10:53 pm
What does the P mean?
Posted : 27/01/2010 12:34 am
