29er frame - 650b f...
[Closed] 29er frame - 650b fork
[#11964853]
The current mad world we live in means I cant finish my bike build as I cant get the 29er fork I want (well not for sensible money anyway).
I was looking at a 150mm travel for a Bird steel 29er hardtail but as a stop gap I have a 650b 160mm 2018 Lyrik ultimate. frame spec is 140-160 travel. I can fit the 29er wheel into the fork. Offset is similar, axle to crown isn't a million miles out and with no air in the fork the wheel doesnt strike the crown or frame.
The stock answer to "can I run it like that" is "NO. You'll instantly crash and die amidst fire, lightning, thunder and angels". Why I ask why......"er dunno. It's just not recomended. My mate said so" and not much better a response from the tuners and bike shops.
So does anyone know the science of why I'll instantly die on the trail running it like that?
Posted : 17/07/2021 4:20 pm
If you're really really really sure the tyre won't catch on the arch at properly full compression, give it a go. The worst that can happen is that you like it.
Posted : 17/07/2021 4:52 pm
Exactly my thoughts. Gotta strip one bike first so reluctant to do if i only end up putting it back together.
20yrs ago i was told point blank NO to Tioga Factory 2.3 with Bomber Z1’s. Similar crash and die stories. Resulted in an amazing bike to ride!
Posted : 17/07/2021 4:57 pm
I presume the wheel / arch and or frame contact is the only issue? No contact = no issue?
Hopefully it’d only be short term anyway.
Posted : 17/07/2021 5:06 pm
I agree, if everything fits then there's no issue. Forks come with loads more tyre clearance than they ever used to so it's not that surprising that a 29" wheel fits in a 650b fork. You might not be able to run a 2.8" tyre but only one way to find out!
Posted : 17/07/2021 5:40 pm
