29" tyre recom...
[Closed] 29" tyre recommendations
[#2961713]
Hi.
As some here may know. I'm slowly building up an XC-centric bike which will have 700c Open Pro CD rims.
The wheels are being built at the moment, and I'm now wondering which tyres to consider.
I was looking at the Kenda 29" SB8s but some reviews I've read don't seem rate them in the wet.
I'm looking at having a fairly large volume tyre, set on the Open Pros, for road and light off road duties.
I've seen Nedrapier's bike with the continental rubber on, but I don't like conti's.
So I'm wondering what else I ought to consider.
So, suggestions, please.
Cheers.
Posted : 19/07/2011 12:39 pm
Maxis Ardents are reckoned to be pretty good.
I run SB8's & find them ok if you realise that such a tyre has its limitations. For me they work well. If its loose I stick a Nev on the front but there is the obvious weight dissadvantage.
Bonty Jones ACX...they were pretty good all rounders I thought.
2.2 Mountain Kings...I thought they were dangerous. 😐
Posted : 19/07/2011 12:43 pm
takisawa2.
Yeah, I went down hard while on a pair of Contis and never did feel right on them. Bike use to squirm around most unsual like.
So Not having Conti again.
I'll go check out the other tyres, cheers 😉
Posted : 19/07/2011 12:47 pm
schwalbe marathon of some type?
Posted : 19/07/2011 12:49 pm
I quite like Ardents I'm running but, despite the smallish looking profile they dont roll that well on road... fast rolling on road - likes wet - has grip off road - I think thats tyre nervana... a compromise has to be made somewhere.
Ardent upfront with SB8 on the rear ?
Ardents of front and Crossmark on rear, had them on my 29ers and on my 26ers too. Change the rear for a high roller nearer winter.
Avoid the bonty offerings, very delicate sidewalls on them. I had Racing Ralphs which were very fast tyre but pig to seal tubeless
Agreed....
Posted : 19/07/2011 12:52 pm
perhaps
[url= http://www.sjscycles.co.uk/schwalbe-marathon-extreme-hs402-folding-tyre-28-x-160-inch-(42-622)-prod19500/ ]marathon extreme[/url]
but perhaps bit small volume..
depends what you mean my light offroad - perhaps a 2" ordinary marathon
Posted : 19/07/2011 12:55 pm
[i]Avoid the bonty offerings, very delicate sidewalls on them[/i]
Yeah, I've just been reading that.
Gonna nip over to look at these Ardents then
EDIT:
Yeah, I do like Schwable stuff, but would like to know what else is our out there.
Posted : 19/07/2011 12:59 pm
geordiemick00
And I'm looking forward to trying them out!!!
Might just whip that Bonty off it now 😉
Posted : 19/07/2011 1:02 pm
Crossmark rear is good in the dry
2.4 Ralph on the front is great but as said previously a pig to seal tubeless although the new ones are tubeless ready I think.
However, I really like 2.25 ardents (good volume for a 2.25), and just bought a 2.4" for the front to try out.
Posted : 19/07/2011 1:07 pm
rocket rons, racing ralph or nobby nic, tried pretty much every 29er rubber on the market currently and these are the ones I keep commingback to
Posted : 19/07/2011 8:58 pm
Yes I find mine are really dangerous as well, just ask Tazzy 😐
Posted : 19/07/2011 9:05 pm
Maxxis Crossmark rear and Ikon front work well for me. Fast rolling, grippy, the Ikon is surprisingly good in the wet (I'm still using it now).
I've had really bad experiences with Kenda SB8s!
Posted : 19/07/2011 10:43 pm
That hasn't been my experience at all.
I'm a reasonably heavy rider at 105kgs and ride in South Wales which is pretty hard on tires.
I'm running 29-4 and 29-3 TLR and think they're fantastic.
By contrast to above I trashed my Maxxis Ignitors and Crossmarks in no time on the same trails
Posted : 19/07/2011 10:51 pm
I hated Ardents, they felt terribly unpredictable in damp conditions and not much better in the dry. Schwalbe seem to have the best 29er offerings of tyres I have tried, I swear by Nobby Nic front & Racing Ralph rear, the 2.25" come up pretty large too.
Interested to hear how you get on with the Open Pros, I was thinking about building a set for XC use also.
Posted : 19/07/2011 10:52 pm
I'm running a pair of 2.4s on my 29er.. great..its funny though, on my 26" bike I wouldn't run them in anything remotely damp but on the 29er.. I've found them OK in the wet... strange..
Posted : 19/07/2011 11:56 pm
Maxxis Crossmark are a good option. 2.1" width a decent side knob for slidy dampness and a good, stiff centre tread for hardpack/road or just going fast! They're pretty light too.
Enjoy!
Rob
[url= http://www.bigrobracing.co.uk ]bigrobracing.co.uk[/url]
Posted : 20/07/2011 8:01 am
I'm running 29-3 Bontys and haven't had any issues at all with them
I reckon 2 rears would be ideal for what you require
Posted : 20/07/2011 8:27 am
I also run Nobby Nic up front and Racing Ralph rear. I did have Racing Ralph front and rear which were ok but I much prefer this combination.
Posted : 20/07/2011 9:00 am
i have run some bonty jones 1.8s on shimano wheels that were a couple of mm wider than my open pros in my cross bike. I dont think i would want to go for anything with a much larger volume than that on those rims though - something like an ardent would maybe go too rounded and out of shape (and need a high pressure to stay on). The open pro is quite narrow (recommended max tyre 28m) The suggestion of the schwalbe marathon extreme sounds good. i would like a set of those but they are a bit pricy.
If you havent got the rims yet, consider 317 or 319s. they are wider and would work better with a larger volume tyre.
I am currently running land cruisers. They are a good compromise of off road ability and smooth rolling on the road.
Posted : 20/07/2011 9:58 am
Have open pros on my cross bike and have worked exccellently on the road and taken some fairly big hits off. Put alot of this down to a good wheel build though. Finally settled on Maxxis Mud 35 upfront and continental twister 30 on the back which just keeps running, don't even know if you can get them anymore? Quite quick tread wear upfront but it has been the most confidence inspiring set-up yet. If it is light offroad though would back the Marathons suggestion or even the folding Racing Marathons which I found good for towpath type rides. Just gone to 29er with Racing Ralphs 2.25 on Stans Crest. Can roll over anything now but huge speed drop so would be interested in knowing about a better set-up. Crossmark on the rear sounds like it has potential?
Posted : 22/07/2011 1:41 pm
Back to the OP. For the uses you need them for - road and light off road I would go for these new tires.
I use the 26er versions on my hardtail and think they are a great tire.
I quite enjoy trail riding with them too.
[url= http://www.tredz.co.uk/.Halo-Twin-Rail-29er_42195.htm?utm_source=Google&utm_medium=Product_Search&utm_campaign=Froogle01 ]Halo Twin Rail[/url]
Posted : 23/07/2011 10:53 am
