Still looking to get a 29+ frame/fork. I have all the components which is good but also limits me slightly and rules out anything with boost wheel spacing.
As I see it I'm left with:
Singular Rooster - I'm between M and L. Medium I think is a bit short, Large, too tall.
Surly Krampus - Is this getting a bit long in the tooth? Heavy?
2016 Vassago Jabberwocky - Geometry seems spot on (long and low) but quite spendy £750 frame and fork
Stooge Mk3 - Heard rumours of 29+ compatability, but don't know if this is true, and how long away is it
Anything else I could consider?
Singular rooster isn't in production anymore so you'd be looking for a secondhand. that said the rooster sizing is deceiving as you can move the stack and reach a fair bit by playing with the eccentric bottom bracket. The front is high because of the fork but it drops a fair way for stand over.
other options: Niner had something for a while non boost. wont be cheap though. Taiwanese/shand/on-one elevated chanistay carbon thing is not boost i dont think neither is the trek stache.
jones 29+ in true stw style,
New krampus coming out soon, a few modifications, looks a bit more trail-oriented, plus you get Surly's new, covers all standards rear dropout spacing.
My budget is limited and if I could afford it I'd probably just go for the Vassago which rules out Jones 29+ although I'd like one
New Krampus sounds interesting though
Carver Gnarvester. Uses standard 135/142 but offset chainring. Available in aluminium if you're normal sized and ti if you're me (or ton)
2017 Fargo is also 29+ but I think boost along with the woodsmoke.
I'd wait for the new Krampus. I really wish Stanton did a 29+ Sherpa though.
Currently owning a rooster I can tell you that in the lowest gear the chain is within 3mm of the tyre using a chronicle on a Hugo. For that reason alone I think boost rear is probably the only sensible answer. That said the carver solution could make for a reasonable answer.
Duc: Is that with 1x or 2x?
I'm having similar thoughts, tried 29+ on the front (Stooge) and now want the ability to run it on the rear too. Thinking of the Vassago (seems a bit pricey), new Krampus (March release date apparantly), or the Rooster (if I could find one)...
Travers 29er+ (mines the Angus SS/Rohloff model) with rigid or Lauf Carbonara's
I'm running 1x - without it being a fat bike and even with boost I can see no way to run 2x on 29+
To be fair though you need to keep the wheel spinning reasonably quickly (because of the weight) or drag your sorry arse out of the saddle and get up the hill so I also can't see the point of the lowere gears you'd get from 2X
Another +1 for the Travers
[url= https://c8.staticflickr.com/2/1533/25704055623_c05ec33956_b.jp g" target="_blank">https://c8.staticflickr.com/2/1533/25704055623_c05ec33956_b.jp g"/> [/img][/url]
[url= https://flic.kr/p/Fao1dP ]The awesomeness that is my @traversbikes Russ Ti[/url] by [url= https://www.flickr.com/photos/jimbosussexmtb/ ]Jim Barrow[/url], on Flickr
Without Boost you'll get tyre/chainrub on 2x drivetrain in lowest gears, which really spoils the 'fun' of having awesome grip - 1x and 135mm hubs work OK. I have a custom ti frame from the same Chinese factory that Travers / Carver uses.
How do Surly and Singular avoid boost then?
Surly have their own 2x O.D. crankset which is offset to avoid chainrub. This can be used on their Krampus.
Boost wasn't around when Sam designed the Rooster so he's done the best he can with a 135 hub. It's damn close with a hugo and a chronicle combination.
I still stand by my comment about 2x earlier. I can't see why you'd do it on 29+ it'd feel like you're constantly fighting to accelerate the wheel at that speed. Maybe I don't ride fast enough, far enough, loaded enough to understand.
Did I here you say Travers?
[url= https://c5.staticflickr.com/9/8347/29972468396_63e27476cc_c.jp g" target="_blank">https://c5.staticflickr.com/9/8347/29972468396_63e27476cc_c.jp g"/> [/img][/url][url= https://flic.kr/p/MEyJCu ]RusTi[/url] by [url= https://www.flickr.com/photos/65116677@N02/ ]marcusandcath[/url], on Flickr
You can run 29+ in a Puffin frame too apparently;
http://coastkid.blogspot.co.uk/2016/07/midweek-cycle-singular-puffin-on-test.html?m=1
I'm really happy with my Rooster though would have considered one of these as an alternative had I not backed them on Kickstarter.
Just because no one has mentioned it (and probably no one will, not being massive fans here); the On One Rango is basically a copy of the Trek Stache, but there's no mention of whether it is boost or not.
Quick shot of the Rooster out on the quick evening spin, bit dark sorry...
[url= https://c4.staticflickr.com/9/8114/29926783931_543d719959_k.jp g" target="_blank">https://c4.staticflickr.com/9/8114/29926783931_543d719959_k.jp g"/> [/img][/url][url= https://flic.kr/p/MAwAei ]IMG_1118[/url] by [url= https://www.flickr.com/photos/76459305@N03/ ]bigtuboflard[/url], on Flickr
^ 2nd post I'll think you'll find! 😉
Its nice to see lots of my Travers 29+ builds on this post. It would be rude not to add another!
[url= https://c2.staticflickr.com/8/7584/17037298137_974a926c3f_b.jp g" target="_blank">https://c2.staticflickr.com/8/7584/17037298137_974a926c3f_b.jp g"/> [/img][/url][url= https://flic.kr/p/rXwBaB ]rudy-fat-29-plus[/url] by [url= https://www.flickr.com/photos/125127594@N05/ ]Michael Travers[/url], on Flickr
I plan on running single speed or at most 1X so the boost rear offers no benefit, and would need a new wheel.
The new Krampus looks ideal but Surly has form so could be some time away.
The Vassago looks really nice, but the 70 degree head angle is a degree steeper than I would like
£700 max budget rules out Jones, Travers, Niner
Bugger. Rare to have money burning a hole in my Paypal and nothing to spend it on
Aluminium Gnarvester is porbably the only option then sub £700
I have a brand new unused Rooster in medium yellow. I have recently been diagnosed with a brain tumour so have my hands full with coping with the after effects of surgery, chemo and radio treatment.
Perhaps PM me if interested. Not thought of price,
Brian
Vassago Verhauen 29 plus, awesome bike, 142 rear spacing with swap out style sliders
[URL= http://i87.photobucket.com/albums/k122/simpsan1/Mobile%20Uploads/2016-04/E96DA594-9E99-45E4-A712-26B21C917013_zpsd9vbrjmw.jp g" target="_blank">
http://i87.photobucket.com/albums/k122/simpsan1/Mobile%20Uploads/2016-04/E96DA594-9E99-45E4-A712-26B21C917013_zpsd9vbrjmw.jp g"/> [/IMG][/URL]
We've become Facebook content
I've just got hold of a large rooster (thanks Richard). It's sitting in the garage pending a maiden ride tomorrow, so use that to qualify my opinion, but I would not say it was tall. Not compared to my large horsethief anyway, a fair bit lower in fact, allowing for sag. Don't forget the ebb gives you some extra mm if you set it at 180 degree.
There will be a 29+ frameset coming from Stooge in the spring, working name Dirt Tracker, it's a completely new design with bi-plane forks and promises to be 'rad'. Drawings are done, production starts very shortly.
I think this is appropriate here
[img]
[/img]
Anyone looking for a budget 29+ bike: I'm selling my [url= http://singletrackworld.com/forum/topic/fs-2015-genesis-longitude-29-singlespeed-600ono ]2015 29+ Genesis Longitude[/url]. Advert ends.
Paceman - what carbon forks do you have?
KM79, I have a pair of On-One Carbon Monocoque Forks on my Krampus. Clearance is quite tight but ok with the stock 3" Surly Knard tyre, but they work very well with the slightly narrower Surly Dirt Wizard I currently have on a 50mm Rabbit Hole rim, and a Bontrager Chupacabra fits well too (both much better all-round 29+ tyres than the original Surly Knard in my experience).
These ones:
[url] http://www.on-one.co.uk/i/q/FOOOSCF4709/on-one-monocoque-straight-steerer-carbon-fork [/url]
Here you go...
Anyone wanting more chain clearance, square taper allows wider chain line with longer bb axle.
Its how I ran 2 x on my B+, until I tried a HT2 with more spacers on the DS
Thanks paceman, looks good!
I've just put a pair of these on my Krampus
[url= http://i.ebayimg.com/images/g/yU0AAOSwZLdXPdOD/s-l1600.jp g" target="_blank">http://i.ebayimg.com/images/g/yU0AAOSwZLdXPdOD/s-l1600.jp g"/> [/img][/url]
Saves about 500g overall. Stiff and strong and didn't cost much.
Feels noticeably lighter, even twitchier, at the front. Although the dimensions are supposed to be pretty much the same as the stock fork.
15mm thru axle and plenty of space for the 3" Dirt Wizard.
I'll get photos at some point
An old style carbon fork will be more forgiving.
I can't believe there hasn't been more frothing about the tip off that there is a 29+ Stooge coming!
Jonestown, is there anymore details, photos, geometry available?
Well I'm pretty excited by that prospect.
