27.5 wheels in a 26...
[Closed] 27.5 wheels in a 26"pike
[#6624664]
My wheels are about done in, and i have absolutely no intention of changing my forks out at the moment. 26" pikes.
Usually in the front i have something quite chunky, either Magic Mary or Chunky Monkey.
If i got some 27.5 wheels, Stans Flows probably what are the chances of having enough clearance??
If there is any doubt ill stick with old school 26" but i am curious about this ATM
cheers
Posted : 11/11/2014 11:20 am
No real help as I've got a 27.5'' Pike with Flows but there isn't much clearance with a 2.35'' Nobby Nic. I would be very surprised if it would fit in a 26''.
Posted : 11/11/2014 11:27 am
Ok cool, thanks. I thought it would be a bit tight.
Posted : 11/11/2014 11:32 am
Chances of clearance are about zero. Have a look at the clearance under the fork bridge as it is, if the wheel was 1/2" (12mm) higher, would there be enough space? I'm running the opposite set-up, 26" wheels with Muddy Marys in 27.5 Pikes and even that only looks a fraction generous, there's no way 27.5" wheels will go in the 26" fork with decent tyres on.
Posted : 11/11/2014 11:40 am
If you put an elastic band tyre on it then it'll probably go but not with anything suitable for mountain biking
Posted : 11/11/2014 11:41 am
I've got a WTB Vigilante 27.5 X 2.3 on the front in 650b Pikes, and it is definitely not swimming in clearance. I'd be surprised if it fitted at all into a 26" set.
Posted : 11/11/2014 11:58 am
Ok, all info much appreciated. Original plan has been set in motion. Old school 26" is the future 🙂
Posted : 11/11/2014 5:29 pm
