27.5 V 29 hmmmm...
[Closed] 27.5 V 29 hmmmm...
[#5697012]
27.5 x 2.35 against 29 x 2.25,both Nobby Nic, there's not much in it is there??
hmmmm
believe the hype 😉
Posted : 16/11/2013 4:20 pm
,both [s]Nobby Nic[/s]Schwalbe
Posted : 16/11/2013 4:37 pm
Do you reckon a narrow enough 29er tyre could make the trails come alive?
Posted : 16/11/2013 4:39 pm
Seriously? Again?
Posted : 16/11/2013 4:41 pm
Says hans dampf on the tyre, are you on the beers?
Posted : 16/11/2013 4:43 pm
Bit overbiked for the park???
Posted : 16/11/2013 4:44 pm
The 27.5 is nearer than the 29, so you have to allow for perspective 😉
Posted : 16/11/2013 4:45 pm
nmdbasetherevenge - Member
are you?*
*try reading more than one post 😉
cbmotorsport - Member
not for the tea and cake stop though
Posted : 16/11/2013 4:51 pm
Its got to be said, my mates norco made more sense when he put the massive Hans dampfs on it. But it didn't make as much difference as that PIC suggests.
Posted : 16/11/2013 5:03 pm
My 650b wheels with 2.4 highrollers measure 28.5"
Posted : 16/11/2013 5:12 pm
 DT78
*chuckle*
I thought the same 🙂
Posted : 16/11/2013 5:19 pm
Posted : 16/11/2013 5:24 pm
The 29er is nearly a whole bike length ahead of the 27.5, you wouldn't need a photo finish to sort that one out, it's clearly a lot faster.
Posted : 16/11/2013 5:35 pm
DT78 - Member
*chuckle*
I thought the same
most of the rest of the "park" looks like this though
Posted : 16/11/2013 5:36 pm
What head angle for the park?
Posted : 16/11/2013 5:42 pm
rocketdog only rides park
Posted : 16/11/2013 5:47 pm
Hitting that tree must have hurt..
Posted : 16/11/2013 5:50 pm
the difference in the wheel sizes is more pronounced on the further away shot. Up close seems to be distorting it a bit.
Posted : 16/11/2013 5:55 pm
more footy pitch,bowling green, pavillion and pitch n putt riding here
Posted : 16/11/2013 6:05 pm
^ That does look like a fun park
Posted : 16/11/2013 6:12 pm
Me likee the dark colored looking bike 😉
Posted : 16/11/2013 6:13 pm
Aww.... we didn't mean it rOcKy
Posted : 16/11/2013 6:14 pm
No worries, it just hasn't been photoshopped very well. The second one with the yellow bike (oops!) is a bit better, but the head is way too large for that body (which is Gee Atherton's, I believe).
8)
Posted : 16/11/2013 6:15 pm
you have made Ben's day 😀
Posted : 16/11/2013 6:18 pm
The HD's look a lot fatter then the NN's
Posted : 16/11/2013 6:32 pm
Ahhh but did the trail develop a pulse and start breathing when you got on the 27.5er?
Posted : 16/11/2013 6:45 pm
asterix - Member
[b]Funniest post reply EVER......[/b]
RocketDog, just get yourself a Fat Bike and stop worrying, you know you NEED one
Posted : 16/11/2013 6:56 pm
650b is aload of tosh , I've owned it and it's rubbish , they should of kept 26inch and 29ers
Posted : 16/11/2013 7:14 pm
too mainstream now John
Posted : 16/11/2013 7:16 pm
 JCL
There is definitely not a lot in it when you put a much smaller tyre (don't believe the numbers) on the 29" and place it behind the 650b bike. Funny enough that headtube on the 650b bike looks like it would be too big for the 29" too 😉
Posted : 16/11/2013 7:17 pm
Lickeys rocketdog?
Posted : 16/11/2013 7:55 pm
I recognise that place.
(RD's pic, not the caravan )
Posted : 16/11/2013 8:31 pm
Massive tyre closer to the lense appears almost as big as slightly smaller one further away shocker
Posted : 16/11/2013 10:21 pm
The blue heckler is mine, ridden exclusively 26" until today. All I have to say is that wheel size doesn't matter one bit, but the smile on my face that just won't go away after today's ride does!
Posted : 16/11/2013 10:34 pm
Burn the witch.
Posted : 16/11/2013 11:55 pm
I have one bike with a 26" 2.4 high roller and another with a 650B 2.1 racing ralph. The difference in circumference for these is also negligible. The only difference I can see at the moment is that the racing ralphs will probably end in a slippery death for me due to the volume of mud around the Kent trails
Posted : 17/11/2013 12:37 am
I struggle to see why the same argument (which is inherently flawed) is made again and again. Try putting the same tyre of the same width on a (more or less) identical rim and then make your point.
Say for example a 26, 27.5, and 29 Schwalbe Racing Ralph on ZTR Crests at 30psi - then feel free to spout as much nonsense as you like.
Comparing different tyres on rims with different profiles is just stupid.
Posted : 17/11/2013 12:57 am
My 26" x 2.35 hans dampf measures 27.25 inches on a stans crest, can i join the 27.5" [i]trail comes alive[/i] debate or does my lack of .25 of an inch mean i'm cast aside with all the other wannabe 26" riding freaks?.
Posted : 17/11/2013 1:16 am
Also, forgot to mention this, all the tyres should be the same width.
Can we actually get the measurements of a 26, 27.5 and 29 x 2.25 on Crests at 30 psi? Then we can finally put this stupid debate to bed.
Posted : 17/11/2013 8:20 am
My Bonty TLR 29-4 on a 19mm internal width rim measures 29.5". Can I join the almost Krampus club?
Posted : 17/11/2013 8:27 am
Different volume tyres in different size shocker?
Posted : 17/11/2013 8:28 am
Well if they are so similar we dont need 650b. There, solved.
Posted : 17/11/2013 8:47 am
I'm missing something.. A fat tyre on a small wheel is nearly the same as a thin tyre on a big wheel? What about a fat tyre on a big wheel and a thin tyre on a small wheel? Or a fat tyre on both sized wheels, or a thin tyre on both wheels?
Or both wheels with no tyres? Or both tyres with no wheels? Or no tyres and no wheels?
Onandonandonitgoeswhenitstopsnobuggerknows...
This is me vvv
I may be cute, but I'm very sad...
Posted : 17/11/2013 10:05 am
I think the point is... that a change of tyres makes a difference. If you want to go bigger, it might be worth trying a bigger tyre before changing your whole bike.
Posted : 19/11/2013 3:27 pm
Smaller wheels with bigger tyres are nearly as big as bigger wheels with smaller tyres shock!
Posted : 19/11/2013 3:49 pm
