Hi guys,
I have been offered a set of 2018 Fox 36 150mm forks for a good price. They are 27.5+/29 but my bike is running standard 27.5 wheels with 2.4 tyres. I know they will physically fit but is there going to be any problems by doing this?
Also I want to increase the travel to 170mm, I think the below air shaft is correct for the forks:
Anyone care to take a look and confirm this is all OK before I buy in.
Thanks
Won't it jack the front ever so slightly and result in a slacker head angle.
It’ll raise your front end by a bit, depending on what you have on at the mo, thus slackening the HA. BB will come up a bit too
20mm on fork = approx 1 deg off HA but you'll gain a bit back as you lose some of the height difference in sag. Offset will likely be different too. BB change will be marginal.
