27.2 dropper rigidi...
[Closed] 27.2 dropper rigidity
 TimT
[#10751720]
I've got a PNW Pine 27.2 110mm dropper which has so much front-to-back flex that I feel like I'm on a pogo stick when I'm sat pedalling. Any recommendations for a more rigid 27.2 dropper?
Otherwise the Pine is great so I don't want to sound too negative.
Posted : 05/08/2019 10:29 am
I've got the KS Eten Remote:
https://www.ebay.co.uk/itm/223547227375
I upgraded the remote to one of the £20 Bontrager ones and it's been excellent for 3 or so years now. I run a full outer on the remote which has made it more reliable but it's been fine. I can't honestly say that I notice any front to back flex having ridden it on a full suss and a hardtail but I am sure that it must be more flexible than a larger diameter rigid post.
PM me if you wanted to negotiate a swap to test it?!
Posted : 06/08/2019 2:59 pm
I’ve got a KS lev integra, bloody expensive but very much as good as my reverbs on the bigger tubed bikes. No flex that I can tell. Does make for a firmer ride than the carbon post.
Posted : 06/08/2019 3:42 pm
 TimT
Thanks Tim. And thanks heaps for your generous offer of a swap test, but unfortunately the travel time between Australia and the UK probably makes that unviable.
Posted : 07/08/2019 8:20 am
 TimT
Nick, how much drop does your Integra have? 65mm, 100mm or 120mm? Ideally I'll be getting 120, 100 would be ok, but 65 is too little.
Posted : 07/08/2019 8:23 am
Thomson. Also expensive - got mine refurbed from Wiggle's Ebay outlet. 125mm drop.
Posted : 07/08/2019 3:05 pm
