Does anyone know where I can get a 26mm 6 sided socket - but without the chamfered bit that you usually get in sockets?
I know I can buy an ordinary one and get it ground down, and I know I can get them apart by carefully using an adjustable spanner but I like to do things properly where practicable and possible.
Thanks
Got mine from the smiling face above. Way cheaper than the ones I saw on ebay.
Do all fox forks need this for a lowers service? I've got this job on my list, but hadn't realised I needed a special tool.
only 32s
Mojo's sell them too, and the bigger one for 36mm forks.
You need the socket if you want to access the float air chamber or drop the damper out. Just an oil change; not required.
34, 36 and 40 s all benefit from using machined sockets as the flats on the topcap are all pretty low profile and made of aluminium so fairly easy to damage
Just looked at their guide. Yep looks like it's only a damper service that needs it. Phew. I usually save that job for people who know what they are doing 😉
Local hardware shop and 20 mins hard graft with a decent metal file. Proper job!
impact driver sockets are just the job as well.
the only good silverline tool i ever had was a set of impact driver sockets - nice thin wall and 6 point face drive.
Local hardware shop and[s] 20[/s] 1 mins hard graft with a decent [s]metal file[/s] grinder
Belt sander does the job in 30 seconds if you have one..
Lathe 10 seconds 😛
once remember a chap on here asking the same iirc i got a socket for about 5 quid and lathed the front off it
and gave it him
ps the socket...was not a euphemism
I have one I no longer need. Yours for £5 posted. Drop me an email if your interested.
I use a 1" OE wrench on mine. Simples.
26mm cone spanner from park tools
http://www.sjscycles.co.uk/park-tool-scw-26-shop-cone-wrench-26-mm-prod32805/
Are they not too hard to lathe down? I ground my last one of a sharpening wheel thing
They are a bit hard and it takes a while to turn them down along with wearing the tool down a fair bit, it's not the method we use although a lathe is involved 😉
Thanks for all your replies, very helpful.
