26" Ardent on i18 R...
[Closed] 26" Ardent on i18 Rims.
[#12218820]
Trying to find some decent 26" tyres for my new old 2009 Genesis IO ID after a weekend of slip sliding around the Dales on an old Conti Mountin King front and getting no traction from a Maxxis Aspen on the back:)
The original Rims are in mint condition, they're Alex XD-Lite 559x18 (i18 I believe).
The stock tyres new from Genesis were Mountain King 2.2
Looking at 26" Maxxis around the same size there's
Ardent 2.25
Minion DHF 2.3
High Roller 2.3
all only a couple of mm wider than the Mountain Kings; But I'm reading Maxxis design these tyres for modern Rim width.
I'd like to use a modern tyre, but am I going to regret putting a modern tyre on an 18mm Rim? would I be better getting somthing more period like some Panaracer Fire? Am i worrying about it too much and should just buy the Maxxis and see how it goes etc.
Posted : 01/02/2022 9:56 am
I have an old 2.25 Ardent 26” as a rear on a 19mm rim. It’s not the best for grip but I find it a good halfway house between grip/rolling resistance for the trail center stuff it’s used on. I think the WT tyres maxxis do now are for the wider rims, so if it’s not WT it should be fine.
Posted : 01/02/2022 10:11 am
Cheers Andy, That's good info. Looks like all the WT tyres are 27.5" 29" so hopfully the 26" will be fine.
Posted : 01/02/2022 11:05 am
I have run 26” 2.3 Ardents on 19mm and presently Aggressors on, I think, 21/22mm DT Swiss rims. I can’t tell any difference apart from the Ardents roll slightly better on the road in-between bridleways.
I can measure both inflated tyre widths for you if clearance is tight - mine are on a 2000 Orange Gringo.
Hope this helps.
Posted : 01/02/2022 11:25 am
If it is limiting your the choice then maybe consider new rims. If you get the same erd it's an easy swap. 26" rims are prey cheap now. You'll get a decent pair for less than the price of one tyre (although that maybe says more about current tyre prices).
Posted : 01/02/2022 11:29 am
@nickjb - That might be the way forward; I've ordered an Ardent to see how it fits but I would like somthing with wet weather in mind for the front like a DHF, so I might look at the rims.
Thanks @wheelsonfire1, I dont think the clearance will be an issure there's quite a gap front and back at the moment, you could probably get a 27.5 on the back TBH. I hope you've got Bar-ends on that Gringo!
I'm coning back to this after ten years off. Amazing how fast the industry abandons tech.
Posted : 01/02/2022 1:13 pm
@jim853 6mm clearance either side on the chainstays with the 2.3 Aggressor’s, more with the Fox 32 forks. As for the bar ends - they were so 90’s! (Got stubbies on my general purpose Marin San Raf though!)
Posted : 01/02/2022 4:26 pm
I am leaning towards new rims I think.
What width would be apropriate for most modern XC + Trail tyres? would 30mm do it all? I wont be racing 🙂
Posted : 02/02/2022 11:38 am
Just keep them pumped up nice and hard and you'll be fine.
Posted : 02/02/2022 11:56 am
26" ardent on an i18 rim:
Pic 001
Pic 002
Pic 003
looks ok, but haven't rode it yet.
Posted : 06/02/2022 8:34 pm
sorry. terrible English... I haven't ridden it yet.
Posted : 06/02/2022 11:45 pm
