25.4mm bars into an...
[Closed] 25.4mm bars into an oversize stem
 PJay
[#1960047]
I've found the [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=25136 ]Straitline shims[/url] for fitting 25.4mm bars into an oversize stem. The description says for Straitline stems, is there any reason I can't use them for other stem/bar combinations?
Posted : 04/09/2010 5:34 pm
Probably not , at a guess the shims fit the Straitline stems flush and look a bit prettier.
Posted : 04/09/2010 5:49 pm
Should be o.k. as long as your stem face-plate and neck has straight edges so it fits snug with the flanges on the shims. Wouldn't do it if stem has a curved face-plate / neck.
Posted : 04/09/2010 5:52 pm
 PJay
Are there any other options out there? I'd be looking to fit 25.4 Raceface Deus bars to a Thomson Elite x4 stem until I need new bars.
Posted : 04/09/2010 5:56 pm
i use easton ea30's with shims as they dont make a 25 used for the last year and been fine.
Posted : 04/09/2010 10:48 pm
 PJay
So could I use these shims with a Thomson Elite x4?
Posted : 05/09/2010 3:56 pm
you would have to check the shape against the thompston stem as they are same shape as easton stems will try and get a pic for u tomorow also i think dmr do some aswell
Posted : 05/09/2010 7:21 pm
