25.4 to OS- why doe...
[Closed] 25.4 to OS- why does the OS feel taller?!
 hora
[#2584817]
Ok, currently have 25.4 high rise bars and ideally wanted to go to Easton low-rise but of course 25.4 bars are being phased out in favour of over-sized bars.
Current set up:
Thomson Elite 50mm zero rise
EA70 high rise bars
So...I've ordered:
Thomson X4 50mm zero rise OS
low-rise EC70 CNT bars
Looking at them- the radius increase in particular it looks like the new set up is at least equal to a older mid-rise 25.4 equvillient set up?!!!
(Or does it equal out and it'd be low rise etc).
In a nutshell I want to go low-rise as opposed to current hi-rise however the OS new set up seems to be more mid-rise (not fitted yet) but visually it looks this way.
Any user thoughts when you changed from 25.4 to OS?
Posted : 21/03/2011 3:47 pm
 AdeC
you can check the rise of both setups by leaning the bike against a wall (use a spirit level to ensure it's straight), then mark where the top of the grip rests against the wall. Swap to the OS stem/bars and do the same.
31.8 bars are way stiffer than 25.4 bars. Once you're used to the look of OS bars, the 25.4's look rubbish!
I use a similar setup to yours (thomson X4 70mm stem with easton EA70s) and its sweet.
Posted : 21/03/2011 5:18 pm
It might be because the newer bars are a bit widder
Posted : 21/03/2011 5:22 pm
Bruce my thoughts. As the bars get thicker the top of the bar gets taller
I'm a amazed at the at patience some people have changing bars to achieve the correct ride height. At the moment I haven't even got round to rolling mine up a bit , which I think will help
Or quick fix. let some air out of your forks, quicker and save weight and money
Posted : 21/03/2011 7:15 pm
 hora
Kinda negates the whole idea of swapping out to get a lower-rise though 🙁
Posted : 21/03/2011 8:10 pm
