24mm Bottom Bracket
24mm Bottom Bracket
[#12746276]
Other half needs a new BB to go with her Race Face Aeffect R cranks. Currently has a Shimano XT which is a bit grumbly.
I'd just replace with the same but getting the cracks in and out is a bit of a nightmare, the axel is so tight it pushes the top hat from the BB when pushing it through and I don't think it's doing it any good.
So what's good without spending £90 on a Hope?
Posted : 06/03/2023 3:41 pm
Why do you take them in and out? Plenty o grease on the spindle when you install them?
Posted : 06/03/2023 3:44 pm
I've had really good experience with Token bottom brackets.
Posted : 06/03/2023 3:52 pm
Uberbike have been fine for me, and the bearings are replaceable
https://www.uberbikecomponents.com/category/405/Steel-Bearing-Bottom-Brackets-Shimano-HT2-24mm-Spindle-and-SRAM-GXP-Compatible
Posted : 06/03/2023 3:59 pm
I’d just replace with the same but getting the cracks in and out is a bit of a nightmare
because
I don’t think it’s doing it any good.
It isn't, it might not be doing any "harm" to the BB either mind but you'll stop noticing a problem that's only a problem because you're taking the cranks in and out.
Put it together leave it alone until it dies. Replace with suitable shimano BB, repeat.
Posted : 06/03/2023 4:07 pm
Replace with the cheapest Deore one you can find
Posted : 06/03/2023 4:16 pm
I’ve done the not-expensive replaceable bearing bb option (uber) and I’m back on shimano MT800 (with aeffect cranks). Minimal faff and a decent life.
Would still like to try hope though!
Posted : 06/03/2023 4:31 pm
Yup, huge fan of Shimano XT BBs
Cheap and seen to last. Hopefully now the parts madness is subsiding we'll soon be back to the days of 15 quid MT800s!
Disclaimer: only applies to threaded, no experience of pressfit. Yet. Ask me in 6 months how the one is on my new bike!
Posted : 06/03/2023 4:38 pm
steve_b77
I've had to take the cranks out 4 times in the nearly two years she's had the bike. Once when I changed the bearings, once when I replaced the chainring, once chasing a creak that I thought might be the chainring and then today. So all for good reason.
I've seen some very mixed reviews of the Uberbike, will have a look at the Token.
Posted : 06/03/2023 4:40 pm
fathomer
the axel is so tight it pushes the top hat from the BB when pushing it through and I don’t think it’s doing it any good.
Nice tight fit, no play. Bit of grease when fitting, job done. Sounds like a win.
Posted : 06/03/2023 5:10 pm
Shimano bb86/92? Fit it properly and it'll be trouble free for yonks.
To my knowledge the original [shimano] bearings can't be replaced like for like and they're a slightly odd size.
Most of the aftermarket replacements don't need the top hats as they're 24mm id. Possibly this is the problem?
Posted : 06/03/2023 5:15 pm
If Praxis make one the size you need I’d try that. I’m now using one of their gxp bb’s and it’s lasting far better than a sram bb - the bearings would have gone all rattly by now but these are still silky smooth.
Here you are - £26.99 @ Merlin. Winner - says it’s Shimano / raceface / FSA 24mm crank compatible.
Posted : 06/03/2023 5:54 pm
@dangeourbrain changed the frame bearings.
Anyway, gone for another XT, two years is acceptable, well just be careful when fitting the cracks.
Posted : 06/03/2023 10:29 pm
Never come close to knocking the tophat off even when using a rubber mallet on the crank, plenty grease and check alignment, sounds like tophats are a better option than axle against bearings type ie hope, token ones.
Posted : 06/03/2023 10:56 pm
That seems far too reasonable
Posted : 06/03/2023 11:05 pm
pickle
I'd go up one, the deore works but it's ime also shorter lived so it becomes a false economy. It can die very fast, in the wrong circumstances. XT is still well priced and a better product.
Posted : 06/03/2023 11:18 pm
I think it depends on the conditions you ride in. Saint, XT and Deore have all given crap life for me - lots of gritty sand and clay.
Posted : 06/03/2023 11:45 pm
The OP didn't actually say what bb shell it was but for threaded 68/73 mm shell I'm another "hard to beat Shimano XT".
For my PF30 bike I've got a Hope PF46. It beats the multiple cheese bearing SRAM units that it replaced into a cocked hat. Yes it's spendy but it just works.
Posted : 07/03/2023 12:13 am
