Following on from the Wide 26" tyre thread,anyone used these on DT Swiss 5.1 rims? and how big are they?
Might not have the rim you want but this should give you an idea: http://www.reifenbreiten-datenbank.de/reifen-Maxxis-Highroller%20II-26x2.40.html
I've them on FlowEX's, good sized without been oversized.
3C on the front and 60a on the back.
Have had them on crest tubeless, just stuck stans in and they were fine. Back to 2.3 now.
How big are the 2.4 compared to the 2.3?
About 0.1 difference 🙄
Nice one.
Thanks for the replies,think I will give the High Rollers a go
They are a bit bigger but have a much tougher casing. I use them on 35mm LB rims which give them a decent profile. Possibly the 5.1 might be a bit narrow to allow the low pressures that these tyres thrive on.
I do have another set of wheels with DT swiss 6.1 rims which are wider,I might try them
