I'm trying to run shimano icetech rotors (203mm) with my avid code rsc's (I believe).
The bike is a nomad 4 and the backend is a 180mm direct post mount. The forks are new lyriks but not the charger 2 dampers - they also have a flush 180mm post mount.
As far as I'm aware I need 23mm PM to PM adaptor but do I need this for the front and back?
It's a right pain! I'd ideally like them just to have 1 set of bolts rather than 2 sets if that makes a difference.
Thanks!
I'd say you need a Hope Mount H for both
Antares +1
I had a look at the hope one but its badly worded on CRC - they have "203mm front 203mm rear" which I believe is probably the model you're referring to.
CRC also have this XTR mount that is +23mm but says front and no mention of rear?
http://www.chainreactioncycles.com/fr/en/shimano-xtr-mount-adaptor-front-post-to-post/rp-prod125652
The other clanger is that there is a comment on CRC that the hope one needed spacers to shim it which I'm hoping to avoid (ocd).
First reviewer on CRC says they've used it on the rear no problem
Shimano do a 180-203 ppm mount that works f & r. There’s an Xtr one and a cheaper one. The Xtr one probably has fancier bolts but they are basically the same
As above, you want a Hope 'H' PM160->PM183 or PM180->PM203. It's what I'm using on my 2018 fox 36s which are also a PM180 mount
Shimano SMMAF203PPM Adapter for post type calliper, for 180mm Post mount to 203 mm rotor.
I just used one to fit a 203 rotor on the rear of a 180mm post mount frame.
lovely ty
