22/34 vs 22/36
[Closed] 22/34 vs 22/36
[#1839468]
Have ridden 22/36 for years but due to the crap chainring clearance on my 853 Inbred (yes I have already attacked the chainstay with a hammer just to get the 36 on) was considering dropping to a 34.
Will I notice much change in top end? (I don't race)
Will I actually get much more clearance?
Should I just buy an mmmbop instead 🙂
Posted : 28/07/2010 10:47 am
Space your crank arm out slightly more?
You'll lose 5.6% on your top gear.
The jump from 12-11T is 8.3% so it's a like losing 2/3 of your top gear.
Posted : 28/07/2010 10:50 am
1 - about 5% difference - on 25mph that's about 1mph
2 - 36T chainring is about 7.3cm radius and 34T is around 6.9cm so it'll add around 4mm clearance (or more depending on the profile of the stays)
3 - since this is obviously what you really want, yes 😉
Posted : 28/07/2010 10:51 am
Have already used a longer BB to get the chainline out as there are only 2 rings, if I go further I think the line will be crap(per)
cynic-al, perfect thanks, that is exactly the kind of thing I was completely unable to work out! Doesn't sound too bad really does it.
Can't someone talk me into changing frames instead!
Posted : 28/07/2010 10:54 am
1) great, not life or death
2) that would help alot I reckon
3) unfortunately not what my wife wants to here
Posted : 28/07/2010 10:56 am
 oink
think the ratio is something like 'for every tooth lost at the front, is the equivalent of 3 at the rear'
Posted : 28/07/2010 5:23 pm
errr i think you mean for every one lost at the back is three at the front maybe?
Posted : 28/07/2010 11:27 pm
 Tim
you will hardly notice it 🙂
Scrub out 34 and write 36 on it in tippex. Used to help a mate when he was riding solo singlespeed races 🙂
Posted : 29/07/2010 9:32 am
use sheldon brown for gear ratio comparisons.
i think you will find that sheldon recommends that you ditch your totally inadequate frame and buy a shiny new one - how about an *insert frame of choice*
Posted : 29/07/2010 9:40 am
ordered a 34, I reckon Tims right I will probably forget it's not a 36 pretty quickly
might buy a new seatpost instead of a frame
Posted : 29/07/2010 10:15 am
inbreds are uncool now, so it's actually very cool to ride one - see?
Posted : 29/07/2010 10:18 am
cool is something I have never managed
Posted : 29/07/2010 10:21 am
