20mm to 15mm hub re...
[Closed] 20mm to 15mm hub reducer??
[#4633403]
I have a non branded 20mm hub, but have some 15mm maxle forks.
Can you get a sleeve or standard reducers other than Hope etc
Ta
Posted : 08/12/2012 5:53 pm
Most hubs/adapters differ form one another so I'm guessing not on the hub -> 15mm adapeter
I presume you can't take the 20mm 'parts' off the existing hub?
Any pics?
re: a sleeve to shim down from 20mm to 15mm. You'll have a problem with the 20mm hub/adapters being 110mm wide and 15mm fork will have a 100mm opening I thiknk
Posted : 08/12/2012 6:34 pm
