20mm Maxle Lite - S...
[Closed] 20mm Maxle Lite - Snapped Skewer
[#3646622]
Rather stupidly I overtightened the skewer on my front maxle tonight and the end of the through-bolt sheared off. The plastic casing part is still in tact. Does anyone know if:
a) I can buy just the replacement part - i.e. the skewer - and where from?
b) If any normal 9mm QR skewer would work? (long shot)
c) Anyone has a spare 20mm Maxle Lite that they want to sell?
Thanks
Posted : 05/02/2012 7:07 pm
Mmmmm try SRAM website and look at the drawings
Posted : 05/02/2012 7:25 pm
Hi bspoked,
The actual skewer rod of the maxle is the same as many normal skewers and i've repaired my own in the past by stripping an old skewer down and using the threaded skewer rod. Pop down to your LBS and see if they have any old skewers lying around.
Its a sound repair and will save you from having to buy a whole new maxle 🙂
Posted : 05/02/2012 11:49 pm
I have heard that you can use a rear hope qr for fork maxles, alternatively I have a maxles light from a lyrik that you can have for £10, this won't fit 32mm forks, well it won't fit my pikes anyway.
Posted : 06/02/2012 12:47 am
Can't help you with regards to getting a replacement.
If it makes you feel any better though, I did exactly the same thing. 🙁
Fortunately my LBS had a spare lever & skewer from a standard Maxle that they let me have for nowt. 🙂
The Maxle Light skewer is alloy, the standard is steel.
I now have a Maxle light with a steel skewer. Happy bunny.
Posted : 06/02/2012 12:51 am
Thanks all. It is for 32mm stanchions, but I will check out that hope skewers and have a chat with lbs. Cheers.
Posted : 06/02/2012 7:56 am
Part no. R1722010 from Fishers, rrp £28.99.
Posted : 06/02/2012 8:48 am
Thanks Coatesy. There if I need to resort to doing it properly!
Posted : 06/02/2012 10:03 am
