20mm bolt through w...
[Closed] 20mm bolt through wheelset choices?
[#3597584]
Before I click on the "buy" button at Merlin for a set of ProII/719s, can anyone suggest any other alternative wheelsets for below £310? Have Bonty got anything worth considering below this price range?
Rear is standard Q/R and the front is 20mm. There seems to be a dearth of 20mm wheelsets of late...
Posted : 23/01/2012 11:22 am
 br
I just bought a Hope Hoops (Pro 2 SP Crest) wheelset at my LBS for £310 - couldn't see anything better, especially at the price.
Posted : 23/01/2012 11:24 am
Depending on how far under the £310 you want to go: £150 from on-one
can be converted between 20mm Maxle/bolt through, 15mm Maxle Lite or 9mm QR in seconds using the supplied adapter cups.
http://www.on-one.co.uk/i/q/WPOOMAX/on_one_max_adaptable_maxle_wheelset_
Posted : 23/01/2012 11:31 am
I'm fast reaching the same conclusion... The only things I can see that come close are Rovals but I don't know if the hubs coem with 20mm adaptors.
[edit] Those On One wheels look quite nice...
Pro 2 on the Stans rim of your choice would probably make more sense tbh.
Rovals are excellent though- finally hammered one of my sets to the point it needed some proper attention but it took an outrageous amount of abuse to do it.
Posted : 23/01/2012 9:03 pm
