203mm = 200mm Disc ...
[Closed] 203mm = 200mm Disc Size Question
[#408802]
I have been lucky enough to get hold of a front wheel that comes with a 200mm disc on it. Does this mean I need a 20[b]3[/b]mm adapter to get it to work? or do I have to track down a 200mm adapter?
Posted : 20/03/2009 6:13 pm
or change the disc over to the size you have
Posted : 20/03/2009 6:18 pm
Well, assuming it's been made exactly to spec it's 3mm larger across, so only 1.5mm on each side (if you see what I mean). Personally, I'd take a washer etc out from the adapter mounts and call it good enough.
smurf
Yes Junkyard, seems like the right thing to do. However it is a [b]5[/b] bolt disc.
Posted : 20/03/2009 6:21 pm
I thought the 5 bolt rotors were 205 mm. Certainly the ones are on my enduro 4 calipers. Still, 2.5mm on the radius is not much. I plan to fit some 165mm rotors to some Avid BB7 road calipers (that normally take 160) and fine tune it with a couple of washers.
Posted : 20/03/2009 6:28 pm
As long as you've got >1mm clearance between the edge of the disc & the caliper (for expansion) it should be fine.
Posted : 20/03/2009 6:37 pm
Try it and see. What's the worst that could happen?
Posted : 20/03/2009 6:57 pm
Running a 183disc on a 185 adapter, no trouble here.
Posted : 20/03/2009 7:04 pm
