2019 Sektor air spr...
[Closed] 2019 Sektor air spring issues
[#10595093]
Anyone any knowledge on the 2019 Sektor air spring / shaft?
I took them apart to see about upping the travel (which you can still do with spacers on said fork) but having put them back together it would seem that the pressures aren’t equalising correctly and there’s no negative pressure as they aren’t sagging properly and topping out with a bit of a clunk.
They work fine other than that.
Theres no dimple on the inside of the stanction so presumably the air equalises via the air shaft elsewhere rather than the norm on the pikes etc?
Posted : 24/04/2019 12:50 pm
Bump for the evening folks.
Posted : 24/04/2019 8:26 pm
