2019 lyrik oil leak...
[Closed] 2019 lyrik oil leak?
[#11190398]
Hi,
I think I might have a oil leak from my 2019 RTC3 lyrik 180mm,from under the compression adjustment cap on the damper side at top of fork. It only seems to be very slight. I removed the lsc screw and wiped clean but the small amount of oil slowly returns after a few rides. Has anybody else had this issue, and is it even an issue or normal, or am I being silly? If it is, what’s the plan of action to getting it fixed?
Thanks all. 👍
Posted : 13/05/2020 5:53 pm
Compression needle O ring I should think. Easy to access. Lookup how to bleed a charger damper. you'll be able to see the needle since it's an integral part of the bleed.process.
Posted : 13/05/2020 7:00 pm
I would send it in for warranty (if its less than 2 years old and you have proof of purchase.
Rockshox dont sell spare parts or seals for the top of the Charger 2 damper (Original Charger damper was fully serviceable).
DIY fixes
https://www.boxxerservis.cz/2020/01/rock-shox-charger-2-unik-oleje-kolem.html
If you google search you will find more threads, 2.1 damper apparently fixes it. Push have instructions to partially dismantle to fit a HC97.
Posted : 13/05/2020 11:19 pm
I have the same problem on one of mine, off to warranty it goes.
Posted : 14/05/2020 9:38 am
