2015/16 Fox 36 axle...
[Closed] 2015/16 Fox 36 axles..
[#7528533]
Did they come with both in the box? Just bought a set second hand but it's only got the 15mm..
Posted : 20/12/2015 12:34 pm
Questions for your seller really?
Posted : 20/12/2015 1:29 pm
Buy them aftermarket and new, and they'll have both, not many will have come with them OEM though.
Posted : 20/12/2015 2:11 pm
No they don't.
Posted : 20/12/2015 2:43 pm
Mine did, you will have 2 pairs of axle skims too. One pair for 15mm and one for 20mm.
Posted : 20/12/2015 3:04 pm
Yep, so have all the ones we've sold, but just found out that 180mm version is 20mm only
Posted : 20/12/2015 4:34 pm
Yep, my 36's where as bitterlemon's.
20mm axle for the standard dropouts, plus a pair of reducers & axle for the 15mm.
That's boxed mind, wouldn't know about oem ones.
Posted : 20/12/2015 4:45 pm
My 2015 180 36 had the both sets of shims and the reducer things in the box but can't rember getting both axles
Posted : 20/12/2015 4:53 pm
They are available direct from mojo (slightly cheaper from active sport for the 15mm ones, not sure about the 20mm) philstone.
Oe ones only came with one (the 20mm in my case) so that may be the issue. If you wanted to swap the 15mm set...
Posted : 20/12/2015 5:07 pm
