2014 Rockshox pike ...
[Closed] 2014 Rockshox pike 160mm problem
[#6447870]
Can anyone help with this one as I'm supposed to be racing at eastridge on Sunday.
Basically with all the air out the forks and top cap off they won't push all the way down and to get 20% sag I'm having to run them at 30psi! The rebound damper side seems to work fine.
It feels like there is some air behind the air piston.. Would removing / refitting the lowers help?
I've tried letting all air out and pumping up to 120psi but still no joy! I've had pikes before and had no problems and usually run close to recommend air pressure guide but these are way off
Dan
Posted : 29/08/2014 7:31 pm
Take a small zip tie and insert it between the wiper seal and the stanchion, press it down past the wiper and see if you get any air escaping from the lower leg.
Posted : 29/08/2014 11:16 pm
Its very easy to undo the lower nuts AMD release any air
How old are they, they only have 5ml of fluid in the air spring side iirc so mine needed a service after 6months
Posted : 29/08/2014 11:20 pm
5ml in the damper side, not the air side. 15ml in the air side.
Posted : 30/08/2014 11:51 am
