2014 kona unit 27.5...
[Closed] 2014 kona unit 27.5+?
[#9346865]
Hi, I can't find any info on the possibility of running 27.5+ wheels on a 2014 kona unit. I know the new ones can, but what about slightly older models?
Posted : 25/05/2017 6:42 am
 Del
doubt it TBH. there's a thread on here that got quite long about what frames and forks would take 27.5+. you'll have to do a search.
Posted : 25/05/2017 8:49 am
Yeah have tried a search. it's not clear. was hoping someone could provide a yes or no answer. all good
Posted : 26/05/2017 6:35 am
I imagine you could run 2.6 tyres (my Unit - which I think it a 2014 - has quite a bit of clearance). Getting a wheelset to fit may be another problem, unless you go custom.
Posted : 26/05/2017 7:31 am
I doubt the rear but I've but I've squeezed a 29+ (40mm int/45mm ext rim) in the standard P2 fork. It has about 3mm each side clearance.
[URL= http://i14.photobucket.com/albums/a333/boff1979/mtb/IMG_20170507_192326_408.jp g" target="_blank">http://i14.photobucket.com/albums/a333/boff1979/mtb/IMG_20170507_192326_408.jp g"/> [/IMG][/URL]
It's a load of fun rigid now. I think 11psi is the sweet spot.
Posted : 26/05/2017 8:07 am
