2013 Saracen 16x fr...
[Closed] 2013 Saracen 16x frameset...
[#4978362]
... WANT!
This one is Manon Carpenters.
I think it's a beautiful looking bike, it just looks right and quite frankly I [s]need[/s] want one.
Still going with the Norglide pivot bushings. Anyone got any experience with them? Performance? Longevity?
Posted : 19/03/2013 11:21 pm
Thomson dropper post? Uses norglide bushes so can't be that bad Shirley?
Looks nice though- as long as you like GOOOOOOLD!
Edit- clutch mech and chain device.. Eh?
Posted : 20/03/2013 4:34 am
nice (and the price to match 🙂 )
Posted : 20/03/2013 4:36 am
To be sure, to be sure?
Looks like a Fox D.O.S.S post. At least I think that's a Fox logo I can see..
Frame is 1150-1450 online... Seems about normal to low on current frames..
Posted : 20/03/2013 6:06 am
althepal - Member
She rides harder than you.
Posted : 20/03/2013 7:28 am
seen them come off, it's a help not a cure
She rides harder than [s]you[/s] most in here.
FIFY
Posted : 20/03/2013 7:33 am
Probably!
Ah yes, doss post- looks similar to the Thomson one though, very similar actually.
Posted : 20/03/2013 9:05 am
You can buy a full bike for just over £1.5k - albeit with a bit of a cack spec and red bits instead of gold...
[url= http://www.ukbikesdepot.com/m15b0s1p7034/SARACEN_2012_Ariel_161_2012 ]http://www.ukbikesdepot.com/m15b0s1p7034/SARACEN_2012_Ariel_161_2012[/url]
Posted : 20/03/2013 9:10 am
Thats the 2012 model too. Not sure if there are any frame changes but you get the Kashima shock etc on the 2013...which is....better?
Posted : 20/03/2013 10:34 am
I'm not convinced myself. Had Kashima and non-Kashima shocks on the same frame and I think I preferred the non-Kashima tbh.
The Saracen suspension is a bit bobby anyway (I had one of the original 140mm ones), so I wouldn't say it needed the Kashima.
I got rid of my Ariel because it was a bit heavy and bobby for long rides. Bear in mind the 160mm frames could be a bit porky too if that matters to you.
Posted : 20/03/2013 11:04 am
Coming from a Mega, I'm not sure it's an issue.. 🙂
Posted : 21/03/2013 12:29 pm
