I went to do an oil change on my 2013 Reba forks and got stuck
(I've done older Rebas).
The air side (left leg) foot nut is deep inside the hollow outer leg. What tool do I need to access it ?
(My 10mm sockets are too shallow)
Is the rest of the servicing the same as for the older forks?
Cheers!
Had the same thing over the weekend.
Purchased a set of these.
http://www.ebay.co.uk/itm/221437510917?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2648
...a deep socket? 😕
One of these or the 1/2 inch variants depending on your ratchet:
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_200503_langId_-1_categoryId_165469
Yep you just need a deep socket.
The procedure for a lower leg service is pretty much the same for all forks and has been for quite a while.
But if doing a air spring or damper service best to download the correct manual from the SRAM website as different spring types have different methods.
