2013 Reba solo air ...
[Closed] 2013 Reba solo air problem
 Bolt
[#5154271]
After blowing the left hand seal out last week (think this was caused by botteming out) have stripped the fork legs off cleaned and lubed etc.
Now seem to have stiction at the start of movement when compressing the forks. Like a dead spot!
Compression and rebound appear to work fine.
Am happy to strip them down fully, just wondered if anyone had a similar problem or any ideas before I do?
Cheers Bolt
Posted : 13/05/2013 9:54 pm
Left hand wiper popping up is usually down to air leaking from air assembly and into lower leg, causing the seal to pop out.
Replace all the seals on the air assembly and you'll be right as rain!
Also you mention they now have stiction? Solo air forks have a weird neg air space that self charges as the fork is compressed (or something like that?) new seals will sort this too 🙂
Posted : 13/05/2013 10:47 pm
