2012 Lapierre Spicy...
[Closed] 2012 Lapierre Spicy -> Zesty
[#4668734]
Having just bought a Spicy 514 frame, I keep hearing that I can use the shock from a Zesty 160mm on my frame effectivly giving me 2 bikes in one.
Does anyone know where I can source such a shock and if not, what the size of the shock on the Zesty is so I can hunt one down?
Cheers,
D
Posted : 20/12/2012 12:23 am
I thought the Spicy was 160mm, isn't the Zesty 140mm?
Posted : 20/12/2012 1:24 am
Not sure it's that simple - think the linkages are a little different.
That said - a 514 frame would be a Zesty, and the Zesty is 140mm, not 160, so you sound all sorts of confused.
Posted : 20/12/2012 9:35 am
Zesty used to be 140mm on the front, spicy 160mm. I'm sure that 2013 Zesty's are 150 up front now though but as for the frame, I believe that if the only difference between zesty/spicy is the shock. The latter using a smaller blanking cartridge to allow for longer travel.
I was tempted to buy one because if you ever feel like the Zesty doesn't have enough travel you can add more on the rear without changing the frame.
Posted : 20/12/2012 9:51 am
I don't think that's true, I've got a Spicy 514 (2012) i.e. It's not a Zesty
Posted : 20/12/2012 10:09 am
The Wrong Trousers - Member
You don't have a Spicy 514. You either have a Spicy 516 or a Zesty 514.
Posted : 20/12/2012 10:11 am
^^^^^^ what he says
Posted : 20/12/2012 10:16 am
I'm not sure of the sizing of the zesty shock, maybe 200 x 57 at a guess. What you will need to do is get some offset bushes (think its burgtec that make them) this will then allow you to run the smaller shock as they alter the I2I dimensions.
Posted : 20/12/2012 11:08 am
If I'm not mistaken all the bikes ending in 4 are Zestys, as in 140mm travel and all the bikes ending in 6 are Spicys as in 160mm travel.
The first number i.e. the 9 in 916 denotes the spec level i.e. 516 is the mid spec Spicy and 916 the top spec Spicy.
Posted : 20/12/2012 11:15 am
^^^^ yep
Posted : 20/12/2012 11:18 am
tinman66 - Member
You're not mistaken
Posted : 20/12/2012 11:31 am
The 2012 Lapierre frames could be converted to run 140mm or 160mm.
You needed a different shock mount or linkage and different shock size.
Not 100% sure about the 2013 frames.
Posted : 20/12/2012 12:09 pm
D'uh ! you're quite correct :oops:, it's a Spicy 916. I'll go away now.
Posted : 20/12/2012 12:23 pm
You can convert a 2012 spicy to 140mm travel by using the longer shock 'extension' from a 2012 Zesty & a 200 x 56 shock .. the linkage is the same.
Posted : 20/12/2012 12:25 pm
For the guys who 'passed the test' [url= ]THIS[/url] is for you. 🙂
For those who got my drift and offered a constructive responce, I thank you.
Apparently, you do need a different shock as well as the adapter between the linkage & the lower shock mount.
When I find the definitave answer, I'll let you cats know. 8)
D
Posted : 20/12/2012 9:11 pm
downhillhotrod; drop me an email, i've looked into this before.
did a post on hear and just got grief for asking to come and measure a zesty/spicy, was told i could be a scamer trying to find out where bikes are then steal them. Muppets!
email no1jeffAT hotmail.co.uk
cheers
Posted : 24/03/2013 8:08 pm
