2011 Speacialized E...
[Closed] 2011 Speacialized Enduro Rear Axle Options
[#4870772]
Hi, I'm thinking of building up a 2011 specialized enduro but put off by the QR dropout setup on the rear. Anyone know what options there are to get to a 12mm or 10mm bolt through and how well that works. I have hope pro2 evo hubs so can change easily to what is needed.
Anyone got a any feedback of how these options run.
currently running an orange alpine 160 with a 12x135 maxle so want a setup somewhere near as stiff as that. cheers.
Posted : 14/02/2013 2:42 pm
Could put on a set of 2012 seatstays for a 142 rear end. Doubt it will make any real difference.
Posted : 14/02/2013 2:49 pm
I used an Azonic 12mm to 10mm stepdown axle on my Demo for years, was spot on. Will allow you to use your 12x135 wheel in QR dropouts.
Posted : 14/02/2013 3:10 pm
given that the enduro has seatstays and chainstays, and the orange doesnt, there shouldnt be a need for a maxle or stiffer axle on the rear
i've not had a problem with stiffness (ooerr missus) on my earlier enduro
however you can get a 9mm (or 10mm if it fits) thru axle from superstar which might allay any fears you have over a qr
Posted : 14/02/2013 3:18 pm
I have an 06 enduro with QR and a 12 enduro with 142 and feel no real difference. I swap the rear wheels between the bikes - one 32 spoke flow and one 36 spoke mavic 721 build and that is where the real difference in stiffness is felt ime.
Posted : 14/02/2013 3:23 pm
Not sure if this works on the Evo hub but if it does it should stiffen it up nicely.
http://www.chainreactioncycles.com/Models.aspx?ModelID=11825
Posted : 14/02/2013 3:27 pm
Thanks for the repsonses! sounds fine, I think the hope converison kit should do it.
I think I was getting caught up in all the must have standards for bikes!
Anyone else done this to an Enduro, feedback is welcomed. cheers.
Posted : 14/02/2013 4:30 pm
