I can't quite work out what is available. Ideally I'd like a 120mm, 15mm axle worldcup but I need a non tapered steerer. is this a possible combination? Online retailers look like they don't stock it, but the info on the SRAM site sounds like every combo is an option.
RLT Ti is the other option of course, which seems to be readily available with the combination I want.
All 120mm WCs are tapered steerer. Stupidly, all 100mm ones (I know you can reduce 120s, but they're heavier) are straight 1.125".
RTL Ti is the other option, you could potentially buy a carbon CSU at some point if the stantions are long enough, I expect RS will say they're not, even if they are!
RLT Ti or XX only option with 15mm maxle and 120mm with 1.8" steerer, both in stock with fishers, give me a call for prices if you like.
Cheers LoCo. Probably about couple of months off yet, I'm just in the planning stage for my proposed new Flux. But I'll drop you a line when I'm ready to go.
