2011 Fox 36 Forks -...
[Closed] 2011 Fox 36 Forks - cracked steerer tube
[#5592015]
Its my own fault, but I hamfistedly managed to crack the steerer tube on my 2011 Fox 36 160mm Talas RLC forks.
So I need to decide whether to sell them as they are with the damaged steerer tube, or get them repaired .
Does anyone know how much a new crown/steerer unit is for these? I see that mojo do a kashima replacement CSU for these for £400, but is there a cheaper option?
Alternatively - does anyone know what these are likely to be worth with the damaged steerer - I wouldnt ride them like this, so I'd say they're only usefull as spares or if you're going to replace the crown/steerer.
They were otherwise in good working order, apart from the cracked steerer.
Posted : 10/10/2013 9:20 pm
if you happen to need a short steerer i've got s spare set you can have cheap. it's only 170mm though i think.
Posted : 10/10/2013 9:27 pm
Steveh - 170mm is way too short , but thanks for the offer.
Posted : 10/10/2013 9:49 pm
 br
How do you crack a steerer tube? 😯
Posted : 10/10/2013 9:56 pm
I found a crack on my 2010 36 Talas earlier in the year. Mojo had replaced the CSU's about 14 months before due to wear on a Stanton. I sent them back and they replaced them FOC!
The previous time was £360 including bushes. They sometimes come up in eBay so maybe worth keeping an eye out.
Posted : 10/10/2013 10:04 pm
by being a hamfisted idiot with a hope head doctor.
Posted : 10/10/2013 10:09 pm
can you cut the end off and put one of these in?
[url= http://www.jejamescycles.co.uk/.bbb-aheadstem-steerer-tube-extender-id21879.html ]Steering tube extender[/url]
Posted : 10/10/2013 10:16 pm
If you were to cut off the section with the crack, how long would the steerer be?
Posted : 10/10/2013 10:28 pm
or buy mine and do the above 🙂
Posted : 10/10/2013 10:32 pm
The crack is at the top of the steerer, but the steerer is cut pretty short as it is, so taking the crack off would lower the steerer by a couple of cm, which would make it too short for most I reckon, would probably take it down to 170mm or so.
Never liked the look of them, just dont trust that they are strong enough for heavy duty use. I reckon they be fine for just riding along, but wouldnt like to trust them for much more.
Posted : 10/10/2013 10:37 pm
eeek head doctor! Tried one once and got scared as it never seemed tight enough.Took it out and knocked a star nut back in! Star nut never seems an elegant solution........but effective!
Posted : 10/10/2013 10:38 pm
Jeez, I'd have though the head doctor would have broke 1st 🙁
Posted : 10/10/2013 10:45 pm
